Jordan Posted July 28, 2008 Share Posted July 28, 2008 So I am very interested in replacing my front brakes I am just curious however... Could I place the stock front brakes on the rear? Link to comment Share on other sites More sharing options...
BlackHole Posted July 28, 2008 Share Posted July 28, 2008 You could if you made the right adapter brackets and had a custom rotor made, but why? Your rear bias would be so extreme I'm not sure you could build front brakes large enough to get the bias back to a reasonable level. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
SBT Posted July 28, 2008 Share Posted July 28, 2008 So I am very interested in replacing my front brakes I am just curious however... Could I place the stock front brakes on the rear? Not sure why you would do this and/or what your goal would be. You'd have to put a monster BBK at the front with some upgraded pads to get your F/R bias back to somewhat normal levels. Otherwise, your rears would be locking up on you in the easiest braking situations - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
praedet Posted July 28, 2008 Share Posted July 28, 2008 Sure, it just takes money... Link to comment Share on other sites More sharing options...
OhBe1 Posted July 31, 2008 Share Posted July 31, 2008 I think a better answer is "NO". Remember the rears have that pesky drum in the hat. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Jordan Posted July 31, 2008 Author Share Posted July 31, 2008 Alright thankyou, What is the best big brake kit for the money, Any suggestions? Link to comment Share on other sites More sharing options...
Whatisit Posted July 31, 2008 Share Posted July 31, 2008 fwiw, front calipers on the rear would mean you would loose your e-brake Link to comment Share on other sites More sharing options...
SBT Posted July 31, 2008 Share Posted July 31, 2008 See post # 5, drum refers to the energency brake's drum/shoe configuration inside the rear disk rotor's hub or "hat" - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
