Honda Hater Posted July 26, 2008 Share Posted July 26, 2008 :confused:I hava a 90 legacy Awd with a 2.2 and I want to do a 2.5 motor swap. I know the motors are similar and that makes me wonder if it is worth it. And I have many questions about doing it. 1. Is it worth it? 2. Will a 2.2 wiring harness work? 3. Will a 2.2 fuel injection system or wiring harness work? 4. Will the 2.2 ECU work? If not were can I find one that will? 5. Will the stock automatic tranny bolt up or hold up to a 2.5? 6. Is a stroker kit worth it? If so what is a good company that deals with stoker kits. Or anything I missed that you might know that I missed would be a big help. Thanks a lot. Link to comment Share on other sites More sharing options...
fastwgn286 Posted July 26, 2008 Share Posted July 26, 2008 not worth it unless the 22 is blown up. in which case, i'd get another 22. you gain like 30-35 hp with the 25, but the onslaught of possible problems and worries about if stuff will hold up isn't worth the trouble Link to comment Share on other sites More sharing options...
