DesertEagle Posted July 24, 2008 Share Posted July 24, 2008 I bought my '06 2.5i 4EAT new and did an ATF fluid drain and fill at 30K. According to the vacation pics, you're supposed to refill it with the same amount of fluid that you drained. Well, I drained a full gallon and replaced it with as much. When I check it with the dipstick, though, the level seems way too high. How much fluid are you guys able to drain? If my level is way too high, how'd it get that way in the first place - from the factory?? Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted July 24, 2008 Share Posted July 24, 2008 My 4EAT came over-filled from the factory. It is still that way because I haven't changed the fluid so I wouldn't worry too much about it. Link to comment Share on other sites More sharing options...
C_randyjones Posted July 24, 2008 Share Posted July 24, 2008 About 4 quarts, maybe 4/12 if you wait it out. IT IS SLOW. Link to comment Share on other sites More sharing options...
porcupine73 Posted October 14, 2008 Share Posted October 14, 2008 You are checking with engine idling and transmission in park on a level surface after shifting through all gears? If checked with engine off it will generally read high. (sorry you probably already know that but sometimes it is the cause). The drain and fill gets maybe 1/2 or less of the total fluid in the trans out. Link to comment Share on other sites More sharing options...
