Impulse Posted July 23, 2008 Share Posted July 23, 2008 So i'm on the verge of getting either the swifts or the rallitek springs, but i have to consider driving through snow in the winter. i know the drop height wont be too bad with either spring, but i was wondering if there is something i should know about progressive vs linear spring rates in the snow? is one better than the other? i'm talking about regular driving and not snow rally or rallycross in the winter (heh, atleast not yet) thanks! Link to comment Share on other sites More sharing options...
Impulse Posted July 23, 2008 Author Share Posted July 23, 2008 eh? i guess not? Link to comment Share on other sites More sharing options...
caramall2 Posted July 24, 2008 Share Posted July 24, 2008 I don't think either will matter, other than what is the final ride height after you put each on (for clearance). If, as you said, both are nearly the same, then I'd go more by how each performs on dry pavement for what you want. Snow shouldn't be a biggie (unless you're "off-roading" it and worried about softer springs causing you to "bottom out" or something...I doubt that's your concern). Link to comment Share on other sites More sharing options...
