unlimited6986 Posted July 14, 2008 Share Posted July 14, 2008 I just through a cel code for PO546. I know its the egt sensor, but its been doing this a couple times. I am stage 2 tune from pdx, fully catless. I dont have the sensor in the uppipe. So what ive been doing is just reflashing the car and goes away for about a month or 2. Has this happened to anyone? Anyway of fixing it so it doesn't keep coming back? Link to comment Share on other sites More sharing options...
unlimited6986 Posted July 16, 2008 Author Share Posted July 16, 2008 Bump going on a trip and wanna make sure my cars gonna be good. Link to comment Share on other sites More sharing options...
ehsnils Posted July 16, 2008 Share Posted July 16, 2008 Short version: http://www.fastwrx.com/p0exgastesec.html I think that will help you. (Even though it's for the WRX ) Link to comment Share on other sites More sharing options...
unlimited6986 Posted July 16, 2008 Author Share Posted July 16, 2008 So i need a resistor for where the plug is? Anyone have a pic of theirs? Link to comment Share on other sites More sharing options...
j255c Posted July 17, 2008 Share Posted July 17, 2008 you can get it at radioshack its i think a 15ohm's its like 2 bucks. I may even have one laying around, if not ill disable the code on friday. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
ehsnils Posted July 17, 2008 Share Posted July 17, 2008 As noted on the link I posted it's a 2.2kOhm resistor that's needed. The challenge is to find the right connector to insert the resistor into, but a bit of cable tracking would probably provide you with a reasonable idea of the correct connector to disconnect. Since the EGT probe is likely to be spent already just leave it in place and disconnect it and then insert the resistor into the connector. Link to comment Share on other sites More sharing options...
unlimited6986 Posted July 22, 2008 Author Share Posted July 22, 2008 Deff need to figure this out hopefully can get it fixed. Anyone have a pic or anything of everything i need? I just need the resistor or do i need that and others things? Just took a 3 hour trip and through that code 5 times there and 3 times coming back. Link to comment Share on other sites More sharing options...
