Pawlwawl06 Posted July 13, 2008 Share Posted July 13, 2008 Hey just curious what these Rotas would look like on a +05 Regal Blue Pearl Legacy(2.5i or GT). I am very close to purchasing. Wondering if someone would go through the trouble to Photoshop the pics. Many Thanks. Here are the Rotas: http://www.wheeldude.com/gallery2/v/newwheels/RotaP1/18x9RotaP1-RoyalGunMetal/?g2_showId=43894 Don't know why I can't insert the image, wtf. Wheel Style: Rota P1 Wheel Diameter (Inches): 18" Wheel Width (Inches): 8" PCD Bolt Pattern: 5x114.3 Offset: 30mm Hub Bore: 73.1mm Color: Royal Gunmetal Photo of the Legacy attached, might need a close up of the wheel though. Anything else I should know before going through with the purchase? I am relatively new to wheel/tire upgrading, its sort of confusing to me. Link to comment Share on other sites More sharing options...
scooby600 Posted July 13, 2008 Share Posted July 13, 2008 You might want to find that in a 5x100 bolt pattern because those won't fit on the Legacy since the car is is 5x100 and the wheels are 5x114.3. According to this thread by Xenonk, they offset may be too low, http://legacygt.com/forums/showthread.php?t=4426 . That is a good reference to go by when shopping for wheels. Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted July 13, 2008 Author Share Posted July 13, 2008 You might want to find that in a 5x100 bolt pattern because those won't fit on the Legacy since the car is is 5x100 and the wheels are 5x114.3. According to this thread by Xenonk, they offset may be too low, http://legacygt.com/forums/showthread.php?t=4426 . That is a good reference to go by when shopping for wheels. Thanks for the help! I see now, those were for the STi. Ok so I found these also, the numbers look much better: Wheel Style: Rota P1 Wheel Diameter (Inches):18" Wheel Width (Inches): 8" PCD Bolt Pattern: 5x100 Offset:48mm Hub Bore: 56.1mm Color:Gunmetal Quantity:4 Pcs. (1 set) Price: $750.00 http://www.wheeldude.com/catalog/product_info.php?cPath=90_217_97_130&products_id=366 This would be a better fit? I'm hoping the 2.5i models do not differ from the GT. Link to comment Share on other sites More sharing options...
EL PAALO Posted July 18, 2008 Share Posted July 18, 2008 That's a proper fit. Link to comment Share on other sites More sharing options...
Spec B Posted July 18, 2008 Share Posted July 18, 2008 Thanks for the help! I see now, those were for the STi. Ok so I found these also, the numbers look much better: Wheel Style: Rota P1 Wheel Diameter (Inches):18" Wheel Width (Inches): 8" PCD Bolt Pattern: 5x100 Offset:48mm Hub Bore: 56.1mm Color:Gunmetal Quantity:4 Pcs. (1 set) Price: $750.00 http://www.wheeldude.com/catalog/product_info.php?cPath=90_217_97_130&products_id=366 This would be a better fit? I'm hoping the 2.5i models do not differ from the GT. That is the proper fit, sent you a PM. Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted July 18, 2008 Author Share Posted July 18, 2008 Thanks guys Link to comment Share on other sites More sharing options...
