Speed_Racer Posted July 13, 2008 Author Share Posted July 13, 2008 ;1964788']Actually' date=' P0000 means there are no trouble codes to report. I don't know why the trip computer would display that code.[/quote'] I read that no the no trouble code is "P----" can someone clarify which is correct? Link to comment Share on other sites More sharing options...
bmorrisj Posted July 13, 2008 Share Posted July 13, 2008 take the car in, make sure they check your fuel injectors, same thing happened to me, but the dealer didnt want to check the injectors, i got aother set and the car idled/ran better, but in the long run the damage had already been done from an injector leaning a cylinder... i dont mean to scare you Link to comment Share on other sites More sharing options...
Speed_Racer Posted July 14, 2008 Author Share Posted July 14, 2008 take the car in, make sure they check your fuel injectors, same thing happened to me, but the dealer didnt want to check the injectors, i got aother set and the car idled/ran better, but in the long run the damage had already been done from an injector leaning a cylinder... i dont mean to scare you I hope I'll be ok. Fingers crossed on a good report! Link to comment Share on other sites More sharing options...
Guest bossies1 Posted October 22, 2008 Share Posted October 22, 2008 Thanks for this thread. My 2.5i wagon had the "CEL/blinking cruise control" issue, and it cleared up after a few starts. It was a few miles after refilling, so I'm hoping that's it! Link to comment Share on other sites More sharing options...
StoplightAssassin Posted October 22, 2008 Share Posted October 22, 2008 ^ Autozone will read any code for free if it comes back. Link to comment Share on other sites More sharing options...
drdave39 Posted October 23, 2008 Share Posted October 23, 2008 I had the same problem at 54,000 miles-turned out it was a bad injector (2005,5MT wagon). Replaced under extended warranty. Same thing 4000 miles later- dealer relaced all the old injectors just to be sure. No problems since then. Dave Link to comment Share on other sites More sharing options...
welby Posted October 23, 2008 Share Posted October 23, 2008 Mine did it once. I forget what the code number was. It was TGV(?) valve related. I have a code reader, so I just reset the code and the car's been fine since then. I do keep the thing in my trunk now, just in case, lol... Link to comment Share on other sites More sharing options...
mmarton Posted October 23, 2008 Share Posted October 23, 2008 2.5i with the same issue more than two months ago. I did the battery disconnect procedure and haven't had a recourance. Link to comment Share on other sites More sharing options...
