silhouette0922 Posted July 5, 2008 Share Posted July 5, 2008 I have a 05 Lgt Automatic. With AC on, then I put i into drive... And I give it minimal gas, under 2500 rpm.... then when the gear changes from 1st to 2nd... there is a little jerk.... But when the AC is off, it doesn't happen... I haven't taken it to the dealer because it only happens it occasionally... Does anyone have a clue? Thanks Link to comment Share on other sites More sharing options...
fishbone Posted July 7, 2008 Share Posted July 7, 2008 A little jerk as in the tranny shifting very firm? Does this happen when the engine is fully warmed, or just when you first start it? If it is doing only when the engine is cold and you first drive it, it should be normal if what you are decribing is a firm shift from 1st to 2nd. The tranny will even keep it in 1st a bit longer than usual. Link to comment Share on other sites More sharing options...
silhouette0922 Posted July 9, 2008 Author Share Posted July 9, 2008 doens't matter if it's cold or warm.,... it occasionaly does it when the AC is on... only in low revs... thanx Link to comment Share on other sites More sharing options...
