PhiTauFord Posted June 24, 2008 Share Posted June 24, 2008 I was contemplating putting this thread in the brake area so if a Mod wants to move this, fine with me. I've had my calipers painted now for a few years. I had taken my car to get detailed and the cleaner they used on my rims ended up ruining the paint job on my calipers so now they look like garbage. Can anyone recommend a product that I can use to remove the remaining paint while hopefully not harming my calipers? Thanks! Link to comment Share on other sites More sharing options...
OCDetails Posted June 24, 2008 Share Posted June 24, 2008 A wire brush and aircraft stripper should do the trick. In order to get all the paint off you are going to have to remove the calipers anyway, so you don't have to worry much about wrecking anything. They are pretty tough and hard to hurt while removing paint. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
Danase Posted June 26, 2008 Share Posted June 26, 2008 A wire brush and aircraft stripper should do the trick. In order to get all the paint off you are going to have to remove the calipers anyway, so you don't have to worry much about wrecking anything. They are pretty tough and hard to hurt while removing paint. That was going to be my suggestion as well. Link to comment Share on other sites More sharing options...
OCDetails Posted July 1, 2008 Share Posted July 1, 2008 Great minds must think alike. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
