Scoobynet_NAF Posted June 20, 2008 Share Posted June 20, 2008 Hi I'm just in the process of installing a Audiocontrol DQL-8 Setup is currently Boston pro60's in the front with K13v.2 sub in custom box (thx Stylion ) in the spare wheel well All driven by apline pdx 4.150 amp Anywhos this DQL-8 has SO many settings I dont even know where to start! At the mo I have everything set flat ( 0db ) except for a slight boost in the fronts at lower freqs i.e 80 - 160 hz Sounds ok but I know it could be so much better I've also tried playing with the subs eq settings but got even more confused ! anyone got any ideas any settings I should try ? thanks Link to comment Share on other sites More sharing options...
