azca Posted June 20, 2008 Share Posted June 20, 2008 Is it possible to use the front LGT brakes (rotors/calipers/pads/lines etc) in the rear? An example would be having aftermarket bigger brakes in the front and LGT's own front brakes in the rear. Any thoughts? Link to comment Share on other sites More sharing options...
PhilT Posted June 20, 2008 Share Posted June 20, 2008 Anything is possible, but you would really need a brake balance controller to be able to adjust them. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
ultrablue Posted June 20, 2008 Share Posted June 20, 2008 the front rotors have no provision for the hand brake Link to comment Share on other sites More sharing options...
DiscoWagon Posted June 20, 2008 Share Posted June 20, 2008 Absolutely not. Link to comment Share on other sites More sharing options...
SBT Posted June 20, 2008 Share Posted June 20, 2008 Might conceivably work, but think there will be issues with the calipers mounting up in the rear without an adapter. Also, no rear drum in the Legacy front rotors for the rear e-Brake shoes, unless you don't care about losing your e-brake/parking brake's functionality. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
praedet Posted June 20, 2008 Share Posted June 20, 2008 Yep! Just like if you get a new engine, you can just move your current one to the back of the car so you have 2... Link to comment Share on other sites More sharing options...
whitetiger Posted June 20, 2008 Share Posted June 20, 2008 racing brake makes a larger rotor kit for the rear that retains the stock rear caliper. this makes the rear rotor diameter the same as the front. Link to comment Share on other sites More sharing options...
SBT Posted June 20, 2008 Share Posted June 20, 2008 racing brake makes a larger rotor kit for the rear that retains the stock rear caliper. this makes the rear rotor diameter the same as the front. I believe you meant, retains the stock rear parking brake setup. Correct? SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
whitetiger Posted June 20, 2008 Share Posted June 20, 2008 it retains the rear park brake and rear caliper. the kit is a larger rotor and caliper bracket only. you use your stock rear style pads with your stock rear calipers. Link to comment Share on other sites More sharing options...
azca Posted June 20, 2008 Author Share Posted June 20, 2008 that doesn't sound like it will give much better braking results though. It looks like we need to go with completely different rear brakes (like Brembos) it retains the rear park brake and rear caliper. the kit is a larger rotor and caliper bracket only. you use your stock rear style pads with your stock rear calipers. Link to comment Share on other sites More sharing options...
bsdzine Posted June 20, 2008 Share Posted June 20, 2008 AZCA, have you upgraded your fronts yet? Currently I am running 316mm rear rotors (RB kit) w/ the OEM 316mm fronts and there's a pretty big difference in downhill braking and high speed braking compared to the OEM 290mm *I believe 290mm* rears... Granted if you are looking to get dual (or higher) piston calipers such as what the front has.... well, then this post is pointless. The RB rear kit w/ simple pads, lines, fluids is pretty nice imo. I'm always up in the canyons and mountains, so those multi-mile all downhill roads are the reason I did the upgrade - it's also almost 70/30 F/R bias. (I think something like .2% - .4% difference F/R) brian Link to comment Share on other sites More sharing options...
azca Posted June 20, 2008 Author Share Posted June 20, 2008 I have upgraded brakes all around (same calipers), aftermarket everything else. Brakes are great but I just got bigger 18" PFF7 wheels (from 17"), so I can go with bigger brakes all around later. Link to comment Share on other sites More sharing options...
whitetiger Posted June 23, 2008 Share Posted June 23, 2008 that doesn't sound like it will give much better braking results though. It looks like we need to go with completely different rear brakes (like Brembos) It does give the LGT perfect brake bias. Unless you are traking the car, ther is no need to upgrade the calipers. There is a thread that contains brake bias and force data on this site. I suggest you read it. http://www.legacygt.com/forums/showthread.php?t=30088 According to the data in that thread, with pads being equal, factory LGT brakes with the racing brake larger rotor kit for the rear has better bias and more braking force than the sti brembo setup. Link to comment Share on other sites More sharing options...
