CypherMax Posted June 20, 2008 Share Posted June 20, 2008 Ok, I am going to be stage II as soon as my Cobb down pipe is off backorder which is around July 20th. In the mean time I have been contemplating on whether or not to get an up pipe to install at the same time as my down pipe. I have read on a few threads that going stage II and keeping the stock up pipe can cause problems with parts of the cat or EGS breaking off and flying into the turbo due to higher boost pressures. First of all should i really be worried about this happening? Second how much will this help performance. All I hear is that the turbo is louder and turbo spool is around 500 rpm sooner. My main concern is keeping my turbo as safe as possible. Lastly what are the best up pipes out there? I have seen only the perrin, invidia, and autospeed (which appears to be the best one due to its flex section to eliminate any chance of leaks during engine rock). I have read countless thread about nightmare leaks on the other brands. Any info or experience anyone has had on this subject would be great. Also if anyone has the autospeed up pipe let me know if its any good. Thanks. Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 20, 2008 Share Posted June 20, 2008 I think the up pipe cat falling apart and going into the turbo are freak incidents at best. You can run a stage 2 map with just an aftermarket DP. I have heard nothing but good things about both the TurboXS and Grimmspeed up pipes. Link to comment Share on other sites More sharing options...
Roppongi Sho Posted June 21, 2008 Share Posted June 21, 2008 The stock STi Up is another option...thats what I picked up. Link to comment Share on other sites More sharing options...
srgdrum Posted June 21, 2008 Share Posted June 21, 2008 You def wanna get an up. My cheap ass megan racing flex up has been trouble free for nearly 2 years. use OEM gaskets. Follow the instructions on the proper bolting down. Link to comment Share on other sites More sharing options...
fonts Posted June 21, 2008 Share Posted June 21, 2008 Get an UP. They are like $100 or so. As for brand ... whatever. They are essentially the same. I'm running a Grimmspeed coated UP which has been great to me so far. If you are concerned about keeping your turbo safe ... don't go Stage II. If you still want to go Stage II get a new UP at the same time. From safety standpoint on the turbo ... yes the cat will break up eventually. Hence Subaru started in 07 with OEM catless UP. It may be a rare thing ... but for $100 after the $$ you paid for your DP and AP is it not money well spent??? Link to comment Share on other sites More sharing options...
TPLGT Posted June 21, 2008 Share Posted June 21, 2008 FWIW, I bot a MR up and DP (catless) cheap and work the balls. Unless you NEED a catted DP, soncdier this setup as it will cost you several hundread LESS than just the Cobb DP. PM Boostjunkie as he can hook you up w/ the package. Rehab is for quitters. Link to comment Share on other sites More sharing options...
CypherMax Posted June 21, 2008 Author Share Posted June 21, 2008 I ordered a grimmspeed up pipe. So ill be putting in that along with cobb dp with AP stage 2 flash sometime in july. Thanks for the advise. Link to comment Share on other sites More sharing options...
TPLGT Posted June 21, 2008 Share Posted June 21, 2008 Good for you..I am sure it will work out well. Rehab is for quitters. Link to comment Share on other sites More sharing options...
fonts Posted June 21, 2008 Share Posted June 21, 2008 I ordered a grimmspeed up pipe. So ill be putting in that along with cobb dp with AP stage 2 flash sometime in july. Thanks for the advise. Same UP and DP I'm running. All has been great. Good luck. Link to comment Share on other sites More sharing options...
Regal05LGT Posted June 25, 2008 Share Posted June 25, 2008 I got the invidia up. First try, no leaks, perfect fitment, but make sure to use new oem gaskets and reinforce them with copper sealer to make sure it won't leak. Link to comment Share on other sites More sharing options...
