westnavy Posted June 17, 2008 Share Posted June 17, 2008 Sorry - new guy here. I don;t know how this got into the "For Sale" topic/thread. If someone can show me how to remove it or if you can do it, I would be most appreciative. I have a 91 Legacy L, which jumped time. Reset all to TDC now won't start. Tested the coil primary (no digital mulimeter, just analog)- tested at 0 ohms. Secondary (all four cylinders were tested and within parameters. went to auto parts store and tested the new one with same results. No spark at plugs. Tested (as per Haynes manual) the igniter at the connection to coil and center pin tests 12v (battery) and the outside pins were tested with LED tester - with no results (unless I am doing it wrong). When I test the terminals (1 and 3) do I test it with key "on" or "off"? Link to comment Share on other sites More sharing options...
