Scooter126 Posted June 15, 2008 Share Posted June 15, 2008 HYO I have a friend with and 02-06 wrx/sti cat back that he want to get out of his shop, so how far off would that be from fitting my 99 legacy? its 3" pipe but it has a back presher plug in the can. It looks close to mine so if its only a lil off i can cut and weld it though id rather not go through all that. thanks Scooter:spin: Link to comment Share on other sites More sharing options...
Reuben Posted June 15, 2008 Share Posted June 15, 2008 Forget about it mate. Unless you have a turbo. A 3" i'm told, will kill your torque. Link to comment Share on other sites More sharing options...
Bdubs Posted June 15, 2008 Share Posted June 15, 2008 +1 for more loss than a gain. Either way, to get it to fit on your car, it would have to be modded in some way or another, i.e. cutting the muffler up and welding it. Link to comment Share on other sites More sharing options...
Scooter126 Posted June 16, 2008 Author Share Posted June 16, 2008 Cool guy thanks for the info. I do want to get a turbo swap going soon but if i have to do a lot of modding to the pipe id like to know how much. is it just at the can or is there more to it. I have a shop to use and im not afraid of cutting stuff up and weldin it back together. Link to comment Share on other sites More sharing options...
SBT Posted June 16, 2008 Share Posted June 16, 2008 You'll definitely have to cut it at some point because the STI mates up to a Downpipe on the right side of the tranny, whereas the Legacy piping runs down the left side of the tranny. And, as others have already indicated, you'll definitely lose torque from the over-sized piping. Is your Leggy an L or a GT? If it's a GT, then your pipe size is likely to be close to 2", but the L will be at/about 1 7/8" IIRC. So you'll definitely need a reducer in the mix too. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
