unlimited6986 Posted June 7, 2008 Share Posted June 7, 2008 Hey im doing my grill right now and need some help. I cut everything off but now my problem is the top of the grill. Do you guys put anything there? i just need to see a pic or some1 tell me what to do. http://img.photobucket.com/albums/v151/oethero/battle%20sigs/sdfsdfe333.jpg http://img.photobucket.com/albums/v151/oethero/battle%20sigs/sddsfdsfdf.jpg Link to comment Share on other sites More sharing options...
05gtlimited300 Posted June 12, 2008 Share Posted June 12, 2008 i bought my DIY grille from another member (had to prime/paint/etc) but if i recall correctly thats pretty much how mine is. I would trim down the two small plastic parts that stick out on either side to just clean it up and to help the mesh sit a little more flush against the grille but you or anyone else would never even notice that part of the grill once its on the car. it would really just look like a straight line across not sure if this picture is what your looking for but you can see how that part of the grille looks once i primed it http://i225.photobucket.com/albums/dd255/scmurray/IMG_0116.jpg Link to comment Share on other sites More sharing options...
collegemt Posted June 12, 2008 Share Posted June 12, 2008 Here is mine from my 08, which I think that is what you have from the pics: http://memimage.cardomain.com/member_images/10/web/2962000-2962999/2962064_65_full.jpg http://memimage.cardomain.com/member_images/10/web/2962000-2962999/2962064_85_full.jpg http://memimage.cardomain.com/member_images/10/web/2962000-2962999/2962064_83_full.jpg Hope this helps. Link to comment Share on other sites More sharing options...
unlimited6986 Posted June 13, 2008 Author Share Posted June 13, 2008 I just left it i got a 05 too, just close up pics. Link to comment Share on other sites More sharing options...
DrCloud Posted June 13, 2008 Share Posted June 13, 2008 If I can get mine to look as good as collegemt's, I'll be a happy camper. It looks as if the grill material is mounted just under/behind the chrome surround, right? Did you cut the surround (or its mounting surface) down to accommodate the material? Thanks, HPH Link to comment Share on other sites More sharing options...
collegemt Posted June 14, 2008 Share Posted June 14, 2008 If I can get mine to look as good as collegemt's, I'll be a happy camper. It looks as if the grill material is mounted just under/behind the chrome surround, right? Did you cut the surround (or its mounting surface) down to accommodate the material? Thanks, HPH On the 08 grill the chrome ring can be removed and the mesh can be stuffed behind it. The chrome ring on the 05-07 can not be removed. Link to comment Share on other sites More sharing options...
TPLGT Posted June 14, 2008 Share Posted June 14, 2008 Here is mine from my 08, which I think that is what you have from the pics: http://memimage.cardomain.com/member_images/10/web/2962000-2962999/2962064_65_full.jpg http://memimage.cardomain.com/member_images/10/web/2962000-2962999/2962064_85_full.jpg http://memimage.cardomain.com/member_images/10/web/2962000-2962999/2962064_83_full.jpg Hope this helps. THAT grill looks unreal! I am soooooo jealous....good work. Rehab is for quitters. Link to comment Share on other sites More sharing options...
DrCloud Posted June 14, 2008 Share Posted June 14, 2008 On the 08 grill the chrome ring can be removed and the mesh can be stuffed behind it... Outstanding. I knew the chrome came off, and it's encouraging to hear the "stuffed behind it" part. I've got a grill for the lower opening just about finished, so I'll be starting on the main one this week. This is very helpful. HPH Link to comment Share on other sites More sharing options...
