eb50 Posted May 22, 2008 Share Posted May 22, 2008 Every few months, my JL Cleansweep volume knob becomes unresponsive and the stereo just CRANKS/BLASTS. in the past, i would just turn down all the inputs and wait it out. today i just unplugged and replugged the input into the CS and it fixed the issue. has anyone else had this random problem? any ideas why it happens? Link to comment Share on other sites More sharing options...
str8dwn Posted May 22, 2008 Share Posted May 22, 2008 Had it with my RF 360 out of the box. It's likely the remote knob. In my case it was a bad phone/ribbon cable. Link to comment Share on other sites More sharing options...
DavidPetrisor Posted May 22, 2008 Share Posted May 22, 2008 look at you radio i had to replace me radio because every so often it would go crazy and make a load wired noise found out that my radio is slowly going bad take a look because the jl cleansweep is top of the line and should not have any problems of could it make wired sounds sence all it dose it let music pass throw Link to comment Share on other sites More sharing options...
eb50 Posted May 22, 2008 Author Share Posted May 22, 2008 look at you radio i had to replace me radio because every so often it would go crazy and make a load wired noise found out that my radio is slowly going bad take a look because the jl cleansweep is top of the line and should not have any problems of could it make wired sounds sence all it dose it let music pass throw unfortunately i ruled that out. it happens with the aux input of the CS as well Link to comment Share on other sites More sharing options...
str8dwn Posted May 22, 2008 Share Posted May 22, 2008 If I remember, the JL cable is simply a normal phone jack cable. Try swapping that out (no need to run wires under carpet yet) to see if that's the issue. Link to comment Share on other sites More sharing options...
eb50 Posted May 23, 2008 Author Share Posted May 23, 2008 the problem is that it happens so infrequently, there is no way to know if that actually fixes it or not. Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 23, 2008 Share Posted May 23, 2008 if its just a phone cord, swap it out, tuck it best you can... and drive till it happens again... if it goes an absurdly long time without happening, id say you found the problem. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
