MaStaMooN Posted May 20, 2008 Share Posted May 20, 2008 http://www.audiointegrations.net/PerfectFit.html http://www.audiointegrations.citymax.com/i/Amp%20Racks/SS_In_Car.JPG http://74.220.202.31/~bellbott/images/airearseatrack12.jpg Fiberglass Tub to hold ur Amps.. attached to the back seat support rails... http://74.220.202.31/~bellbott/images/airearseatrack17.jpg Awesome looking product if you dont mind loosing your pass through. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
executor485 Posted May 20, 2008 Share Posted May 20, 2008 I think the problem is that so many people have differences of where they want their amps to be. 1) Under the seats - dont need any trays 2) They dont want to lose the trunk pass through, considering you open it up for better bass (some people do, like me ) 3) Some want to mount the amps to the back of the seats, but still keep the passthrough 4) Many people use the spare tire tray area... Which would probably be the best spot for someone to make a tray, but then again, its always up to what the person wants. It looks really nice for sure, but I dont think it would be a very profitable endevor honestly. Which is why people probably dont want to waste the time making them. Thats just what I think though, kinda why I wouldnt want to make them, even though they do look good. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 20, 2008 Author Share Posted May 20, 2008 1 - Not enough room under the seats for most normal sized amps. 2 - Would probably still allow you to use the rear-deck sub hole for bass transfer. 3 - The back of our seats are tiny!! Probably the same amount of room as under the seats. 4. One of these for the spare tire area would be great also. Probably sell as well as the wickedCAS box... hard to say if thats profitable though. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
ItalynStylion Posted May 20, 2008 Share Posted May 20, 2008 I saw this on DIYMA last night when some guy got his new amp. I was thinking about posting it. Pretty cool but I don't really see the point. Why can't the amps just be mounted to the rear seats? Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 20, 2008 Author Share Posted May 20, 2008 I wanted to mount my amp, PG zx600ti, to the back of the seats... Unfortunatly at 16inches long, it wouldnt fit... it wouldnt fit without covering the passthrough.. or straight up and down. Maybe my amp is larger than most?? i dont know... I was going to just cut a piece of 1/2 inch MDF and kinda make one of these,... without the tub.. but really wanted to keep the pass through. Im not saying this is ideal for everybody.. but showcars and for people that dont mind the loss of passthrough its a nice look. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
ItalynStylion Posted May 20, 2008 Share Posted May 20, 2008 You could cut a piece of MDF covered in matching carpet like you were saying and put it on some hinges near the top. You could add some threaded T-nuts near the bottom that would allow you to secure the bottom. Then, when you need to use the pass through just undo those little bolts at the bottom and swing the amp rack up and out of the way. It could work pretty well if you put some thought into it. Link to comment Share on other sites More sharing options...
executor485 Posted May 20, 2008 Share Posted May 20, 2008 You could cut a piece of MDF covered in matching carpet like you were saying and put it on some hinges near the top. You could add some threaded T-nuts near the bottom that would allow you to secure the bottom. Then, when you need to use the pass through just undo those little bolts at the bottom and swing the amp rack up and out of the way. It could work pretty well if you put some thought into it. That sounds like a good idea too... Good thinkin there haus If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
Googalash Posted May 20, 2008 Share Posted May 20, 2008 4. One of these for the spare tire area would be great also. Probably sell as well as the wickedCAS box... hard to say if thats profitable though. Audio Integrations has made something like this for the spare tire area. I know cause its in my trunk right now. Link to comment Share on other sites More sharing options...
ItalynStylion Posted May 20, 2008 Share Posted May 20, 2008 Audio Integrations has made something like this for the spare tire area. I know cause its in my trunk right now. Pics of said piece? Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 20, 2008 Author Share Posted May 20, 2008 Like this? http://www.audiointegrations.citymax.com/catalog/item/3595562/4763318.htm http://www.audiointegrations.citymax.com/i/Amp%20Racks/down_position.JPG http://www.audiointegrations.citymax.com/i/Amp%20Racks/up_position.JPG You could cut a piece of MDF covered in matching carpet like you were saying and put it on some hinges near the top. You could add some threaded T-nuts near the bottom that would allow you to secure the bottom. Then, when you need to use the pass through just undo those little bolts at the bottom and swing the amp rack up and out of the way. It could work pretty well if you put some thought into it. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 20, 2008 Author Share Posted May 20, 2008 too bad my amp has a top fan, or something like this would be nice. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
Googalash Posted May 20, 2008 Share Posted May 20, 2008 Pics of said piece? don't have any ATM but I'll get some Link to comment Share on other sites More sharing options...
ItalynStylion Posted May 20, 2008 Share Posted May 20, 2008 too bad my amp has a top fan, or something like this would be nice. As long as you mounted it with the fan underneath the stock sub location it would probably vent just fine. Googalash, that's a bad ass idea for the amp. Up and out of the way and keeps it clean; I like that a lot! I think I will do something like that on a little bit more of a massive scale with my EDNINe.5....I think it's about 28 inches long. The only thing I would like to suggest, if I may, is that you should try and separate your RCA's and your power wires if possible. Link to comment Share on other sites More sharing options...
sportwagon Posted May 20, 2008 Share Posted May 20, 2008 Like this... http://i75.photobucket.com/albums/i299/2fuzzy2/DSC02899.jpg Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted May 20, 2008 Share Posted May 20, 2008 I think the problem is that so many people have differences of where they want their amps to be. 1) Under the seats - dont need any trays 2) They dont want to lose the trunk pass through, considering you open it up for better bass (some people do, like me ) 3) Some want to mount the amps to the back of the seats, but still keep the passthrough 4) Many people use the spare tire tray area... Which would probably be the best spot for someone to make a tray, but then again, its always up to what the person wants. It looks really nice for sure, but I dont think it would be a very profitable endevor honestly. Which is why people probably dont want to waste the time making them. Thats just what I think though, kinda why I wouldnt want to make them, even though they do look good. I love the passthrough! It keeps my mono-block amp from overheating and shutting off. Link to comment Share on other sites More sharing options...
