Rushin Posted May 17, 2008 Share Posted May 17, 2008 Hey! I got a Gimmick STS for my 08 Spec.b. So when i was installing it today i could not figure out how to make the reverse lock out cable to work with a shorter shifter. It seems like the cable is too long now. I am sure some people here installed a Kartboy STS which is very similar to gimmick one, please let me know how you solved the problem. Thanks, Taras Link to comment Share on other sites More sharing options...
Rushin Posted May 18, 2008 Author Share Posted May 18, 2008 I figured out the problem. The gimmick short throw is not designed for the 08 spec.b. So I had to make a spacer for the reverse lock out cable. Its working ok now. The throw is much shorter now. So this is just a heads up to people who are going to buy one. Link to comment Share on other sites More sharing options...
Touge Tuning Posted May 18, 2008 Share Posted May 18, 2008 Kartboy FTW Link to comment Share on other sites More sharing options...
fonts Posted May 18, 2008 Share Posted May 18, 2008 Kartboy FTW Link to comment Share on other sites More sharing options...
MarkV Posted May 20, 2008 Share Posted May 20, 2008 Hey Rushin, 1 Question did you use a screw driver, or so,me sort of mini pry bar to take out the panels to install ur shifter..? or better yet how'd u take off the panels in general? I got an '06 Legacy GT, I just dont wanna crack any of the molding, cuz I'll kill myslef if I do:lol: I've Crashed My ROFLChopper into a LOLCanOhttp://legacygt.com/forums/image.php?type=sigpic&userid=16939&dateline=1230531251 Link to comment Share on other sites More sharing options...
Rushin Posted May 20, 2008 Author Share Posted May 20, 2008 You just need to pull on it hard. Put your fingers under the boot and pull. I did not use a screw driver cause i did not want to scratch the panel. Link to comment Share on other sites More sharing options...
MarkV Posted May 21, 2008 Share Posted May 21, 2008 thanks dude I've Crashed My ROFLChopper into a LOLCanOhttp://legacygt.com/forums/image.php?type=sigpic&userid=16939&dateline=1230531251 Link to comment Share on other sites More sharing options...
Rushin Posted May 21, 2008 Author Share Posted May 21, 2008 no problem! Link to comment Share on other sites More sharing options...
fonts Posted May 22, 2008 Share Posted May 22, 2008 thanks dude Remember that there is a little wiring harness attached to the boot panel/cover that has to be unclipped before you remove. Link to comment Share on other sites More sharing options...
