snowboarder_lgt Posted May 9, 2008 Share Posted May 9, 2008 hi have some door tweeter speakers and need to hook them up. When I pull off the triangle panel in the front corner of the driver and pasenger window there isn't a hookup and I thought there was Do I need to hook tweeters to the stereo, to the other speakers, or is there some cable behind the door panel? Thanks!! Link to comment Share on other sites More sharing options...
SLegacy99 Posted May 9, 2008 Share Posted May 9, 2008 Wait you have a GT and there are no tweeters there? Link to comment Share on other sites More sharing options...
deadlydave Posted May 9, 2008 Share Posted May 9, 2008 What you need to do is pop off the door trim(interior bits of the door). There is a screw holding the armrest on as well as the door handle area, and the rest are held on with pop-off bits. The wires probably just sunk in there, you should be fine. :-) Link to comment Share on other sites More sharing options...
snowboarder_lgt Posted May 9, 2008 Author Share Posted May 9, 2008 GT and nope no tweeter speakers in the door :/ and thanks i will try that thanks!! i dont really know anything about audio so i wasnt sure if i needed wires or what to do before i pulled the door trim off thanks again!! Link to comment Share on other sites More sharing options...
Sarra Posted May 11, 2008 Share Posted May 11, 2008 Did you buy the car brand new back in 97, 98, 99, or did you buy it used? Might have an L door panel on it or something. Link to comment Share on other sites More sharing options...
