COBBsoobyStage1 Posted May 7, 2008 Share Posted May 7, 2008 I recently bought an OBXT. I want to make it hott and fast. I'm looking to order: cobb ap cobb dp cobb pulley what I want to know anyone have a full 3" tbe on their OBXT? what about springs? Link to comment Share on other sites More sharing options...
ShadowImg Posted May 7, 2008 Share Posted May 7, 2008 My understanding is if you want a full 3" exhaust, you don't want the Cobb. If I understand correctly, it tapers to 2.25". If you want to make it hot, I guess you could remove the intercooler and drain all the coolant out. Link to comment Share on other sites More sharing options...
GrayT Posted May 7, 2008 Share Posted May 7, 2008 My understanding is if you want a full 3" exhaust, you don't want the Cobb. If I understand correctly, it tapers to 2.25". If you want to make it hot, I guess you could remove the intercooler and drain all the coolant out. Not hot! Hott! Geeeeeeeeeeeeeeeeeeeeeeeeeeeeez. Link to comment Share on other sites More sharing options...
whitetiger Posted May 7, 2008 Share Posted May 7, 2008 to the OP, why a pulley? Perrin offers a full 3" tbe in sections. Link to comment Share on other sites More sharing options...
ScoobySTi07 Posted May 7, 2008 Share Posted May 7, 2008 Before you go mod crazy, you may want to sit back and think about where you’d like to end up with your mods (i.e. stage 2, stage 3). It'll save you time and money in the long run and enable people on the forum to give you better advice. The Ridiculousness is no more But you can have your very own piece of it. **The Ridiculous Part Out.** Link to comment Share on other sites More sharing options...
COBBsoobyStage1 Posted May 8, 2008 Author Share Posted May 8, 2008 Good point... I'd like to go stage2 on the pwr. I'll probly keep the wheels for a while but springs and sways would be nice. Right now its jacked up like a monster truck. I'm also looking to add some eye burning driving lamps (moding out the grill and custom designing a mount) Link to comment Share on other sites More sharing options...
COBBsoobyStage1 Posted May 8, 2008 Author Share Posted May 8, 2008 to the OP, why a pulley? Perrin offers a full 3" tbe in sections. Because it really improves your engine rev. The OEM main pulley is nearly 10lbs, the Ti one is about 2lbs. Rotating masses.... Link to comment Share on other sites More sharing options...
whitetiger Posted May 8, 2008 Share Posted May 8, 2008 I have a pulley and let me tell you first hand that its not worth the money unless you pair it with a lightweight flywheel. The benefits froma pulley alone are barely noticable and its very little bang for your buck. Link to comment Share on other sites More sharing options...
COBBsoobyStage1 Posted May 8, 2008 Author Share Posted May 8, 2008 I have a pulley and let me tell you first hand that its not worth the money unless you pair it with a lightweight flywheel. The benefits froma pulley alone are barely noticable and its very little bang for your buck. I guess I'm basing it off the wrx I had. I gutted the uppipe PnP, Pulley, tbe and ap2. Everything I'd like to do to the OBXT. that thing was snappy like a turtle. Link to comment Share on other sites More sharing options...
JSaladino Posted May 8, 2008 Share Posted May 8, 2008 that thing was quick like a rabbit. :lol: fixed. definitely a good plan, stage II is awesome! do you have a 5 spd? cuz if you do i'd recommend eventually going with an ACT Streetlite FW and heavy duty street disc, makes a huge difference vs the OEM clutch Link to comment Share on other sites More sharing options...
tommypenguin Posted May 9, 2008 Share Posted May 9, 2008 My understanding is if you want a full 3" exhaust, you don't want the Cobb. If I understand correctly, it tapers to 2.25". If you want to make it hot, I guess you could remove the intercooler and drain all the coolant out. The Cobb DP actually tapers to 2.5";) nevertheless its not a full 3" all the way. Link to comment Share on other sites More sharing options...
ScoobySTi07 Posted May 9, 2008 Share Posted May 9, 2008 The Cobb DP actually tapers to 2.5";) nevertheless its not a full 3" all the way.Either way, 2.5" vs 3" doesn't matter much as Stage II isn't enough to be hindered by the half inch difference. You won't really run into power loss from it until you go to a larger turbo. The AP and downpipe are a good start. As for which downpipe you should choose, if you plan to replace more of the exhaust look at a company that sells their mid pipe separate from the cans so you can keep the stock cans (e.g. perrin, cobb) or you can get whichever turbo back exhaust (TBE) you like the sound of as you can always get the tips cut off and have elbows welded on by your local muffler shop or you could just trim your bumper/get longer hangers. For suspension, one of the vendors sells stiffer springs that you just put on the stock struts but they won't lower you any. The next best choice if you want to change your ride height is going with a full coilover set. As far as I know the only company that offers Outback specific coilovers is Megan Racing. They allow you to go from stock height to around LGT height and everywhere in between. I'd also recommend replacing the rear swaybar at the very least. The stock one is ridiculously tiny and a larger one with nicely improve handling. You can do both the front and rear sway's but I'd do coilovers first and then decide how much stiff you want the car. The Ridiculousness is no more But you can have your very own piece of it. **The Ridiculous Part Out.** Link to comment Share on other sites More sharing options...
COBBsoobyStage1 Posted May 9, 2008 Author Share Posted May 9, 2008 Thanks for the recommendations... yeah, I'm thinkin the DP and let it ride from there. Slap on the stage2 ap and the coilover set.. should work nicely. That'll do for a while. Thanks alot gang! Link to comment Share on other sites More sharing options...
anonymouse20910 Posted May 14, 2008 Share Posted May 14, 2008 Watch out for drone from a full TBE. Wagons are more prone to drone. Go with something that you can put your stock cans on. Link to comment Share on other sites More sharing options...
Kaos22B Posted May 15, 2008 Share Posted May 15, 2008 ...that thing was snappy like a turtle. that thing was quick like a rabbit. :lol: fixed. YOU my friend have apparently never owned a turtle! Link to comment Share on other sites More sharing options...
Kaos22B Posted May 15, 2008 Share Posted May 15, 2008 Oh, and my opinion about the clutches on our cars, get the ACT kid, but NOT THEIR FW, so godamn noisy... Just get an OEM 06/07 WRX flywheel to make it work. Link to comment Share on other sites More sharing options...
OhBe1 Posted May 16, 2008 Share Posted May 16, 2008 I'd suggest working on the handling first. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
