NiTRO Posted April 27, 2008 Share Posted April 27, 2008 Hi, It's not a B13, sorry:redface:. But I think may be it will be for somebody intresting. This is Subaru Legacy Wagon TS type R from Japan internal market. Model code B12, 2000year Engine 2.0 DOHC AVCS (155 ph), AT Now, this car travels on the roads of Russia (moscow) +++ Ooops, I have a mistake. Moderator pls move this post to Legacy Photos. Thanks. Link to comment Share on other sites More sharing options...
zhabodav Posted April 28, 2008 Share Posted April 28, 2008 klassnaya tachka, a skolko loshadok, ia tozhe moskvich Link to comment Share on other sites More sharing options...
idontknow Posted April 28, 2008 Share Posted April 28, 2008 Very nice! Great looking car. Can you post some specs for those of us who are Americans? Link to comment Share on other sites More sharing options...
NiTRO Posted April 28, 2008 Author Share Posted April 28, 2008 of course! SPECIFICATION (SPECS) GENERAL Body type Wagon Drive FULL 4WD Transmission E-4AT (7 position electronic control automatic) Displacement, cc 1994 Frame TA-BH5 Price of new car, thousands yen (Tokyo area) 2521 (~$21000) EXTERIOR Exterior dimensions (LxWxH), mm 4680 x 1695 x 1485 Interior dimensions (LxWxH), mm 1925 x 1440 x 1190 Wheel base, mm 2650 Treads (F/R), mm 1460 / 1455 Ground clearance, mm 165 Curb vehicle weight, kg 1470 Gross vehicle weight, kg Seating capacity, persons 5 Doors number 5 Min.turning radius, m 5.4 Fuel tank capacity, l 64 ENGINE Displacement, cc 1994 Engine model EJ204 Max.power (Net), kw(PS)/rpm 155 ps (114.00 kw) / 6400 rpm Max.torque(Net), N*m(kg*m)/rpm 20.0 kg*m (196.13 N*m) / 3200 rpm Power density 9.48 Engine type Horizontal opposition 4 cylinder DOHC16 valve Engine information AVCS (variable valve timing) Fuel system EGI (electronic gasoline injection:Multiple point injection) Turbocharger No Fuel type Unleaded premium gasoline Compression ratio10.8 Bore, mm 92 Stroke, mm 75 Final gear ratio 4.444 Fuel consumption at 10-15 modes, l/100km 8.4 (Actually my car "eat" ~12.5 l/100km in a city with traffic jumps) CHASSIS / TRANSMISSION Power steering Yes Tires size, front 205/50R16 Tires size, rear 205/50R16 Braking system, front Ventilated disk Braking system, rear Disk Suspension system, front Strut type independent suspension Suspension system, rear Multiple link type independent suspension +++ without LSD 2 zhabodav: 155 ps . pls check pm Link to comment Share on other sites More sharing options...
