simba Posted May 12, 2004 Share Posted May 12, 2004 can I insert the fuse on my 98 Legacy wagon and run it in 2 wheel drive without damage?? Link to comment Share on other sites More sharing options...
03legacy Posted July 3, 2004 Share Posted July 3, 2004 i did it to my 2003 legacy & nothing happened. When i put it back th AWD it reved alot higher at 6500 RPM(in the redline) & I have an automatic if that makes a difference. Link to comment Share on other sites More sharing options...
simba Posted July 8, 2004 Author Share Posted July 8, 2004 I have an auto too. Do you think it will cause long term damage? I asked on the Subaru offical web site and they just said to use the car as designed. They would not give a straight answer. How long have you had it 2 wheel drive? Link to comment Share on other sites More sharing options...
SUBE555 Posted July 9, 2004 Share Posted July 9, 2004 My first question is why do you want/need it in 2WD mode? Link to comment Share on other sites More sharing options...
NicoGamine Posted July 9, 2004 Share Posted July 9, 2004 [quote name='simba']can I insert the fuse on my 98 Legacy wagon and run it in 2 wheel drive without damage??[/quote] Mechanically, I don't think you are damaging much as it basically forces the centre viscous clutch to (almost) totally disengage. The owner's manual says to use it for a limited time only but that is with the small spare wheel, which causes slip in the clutch, so it risks overheating. Dynamically, the car will drive like crap. Nicolas Link to comment Share on other sites More sharing options...
evolutionmovement Posted July 9, 2004 Share Posted July 9, 2004 You could overheat the solenoid that disengages the clutch pack as it's likely not rated for continuous duty. Steve Link to comment Share on other sites More sharing options...
