mmanus88 Posted January 16, 2005 Share Posted January 16, 2005 i installed a set of 6k HIDs recently and they work great, but there are a few quriks that i'm curious about. first off, if i want my HIDs on (or off) i have to always have the e-brake on before i start the car, ande depending whether i want the HIDs on or off determines the light switch. when the HIDs are on, i try to put the light switch to the off position, and they flicker out, then if i put it right back to the on position they don't come back. did i do something wrong here or is this how third party systems work on legacys? Link to comment Share on other sites More sharing options...
ScoobyLife Posted January 16, 2005 Share Posted January 16, 2005 Make sure you disable your Daytime running lights, there is not enough voltage to support HIDs. While your lights are in the off position they will flicker due to not having enough voltage support. I haven't installed my yet, but I think that might be the issue. Link to comment Share on other sites More sharing options...
ScoobyLife Posted January 16, 2005 Share Posted January 16, 2005 I forgot, there is a post specificly for disabling Day time running lights here someone (just do a search for it). Link to comment Share on other sites More sharing options...
mmanus88 Posted January 16, 2005 Author Share Posted January 16, 2005 thanks a ton scooby! Link to comment Share on other sites More sharing options...
liquidiq Posted January 16, 2005 Share Posted January 16, 2005 Yep, disable the DRLs. Link to comment Share on other sites More sharing options...
mwiener2 Posted January 16, 2005 Share Posted January 16, 2005 Yup, you def forgot to disable the DRL's My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
mmanus88 Posted January 17, 2005 Author Share Posted January 17, 2005 did it, works great! stupid thing was i was not sure which connector it was so i was yanking with needle nose pliers and bending some plastic on the electrical work no harm done tho, got the right thing disconnected everything is well Link to comment Share on other sites More sharing options...
Deer Killer Posted January 17, 2005 Share Posted January 17, 2005 Yeah you need to squeeze the tab.. looks like you got it though Link to comment Share on other sites More sharing options...
mmanus88 Posted January 17, 2005 Author Share Posted January 17, 2005 u shouldve seen me, i was pulling at things that definately should not have been touched i don't think i did any damage to the elctrical work since everything is functioning normally as they should. until something goes wrong, i will be satisfied niteynite Link to comment Share on other sites More sharing options...
Deer Killer Posted January 17, 2005 Share Posted January 17, 2005 btw, which kit did you get? Did you have to cut/drill anything on the housing? Link to comment Share on other sites More sharing options...
mmanus88 Posted January 17, 2005 Author Share Posted January 17, 2005 no, no holes had to be made! was able to fit everything through got my kit from http://www.blinglights.com Link to comment Share on other sites More sharing options...
Deer Killer Posted January 18, 2005 Share Posted January 18, 2005 Too bad can't get 4300K or lower in H7.. Would you mind taking some pics of the bulb assembly? Thanks. Link to comment Share on other sites More sharing options...
mmanus88 Posted January 18, 2005 Author Share Posted January 18, 2005 do not have time to show you the innards, but here are my pics (submitted to blinglights for show). gives u an idea of how bling's look compared ot other HID kits (and the stock halogens) my opinion on the HIDS and tis particular 6k kit: iw as blown away when i first fired these babies up. the difference from halogens was night and day! these HIDs light up my whole field of vision while driving and i love 6k because its the perfect mixture between pure white light and an eerie shade of blue. anyone interested in HIDs, these kits are highly reccomended. plus i was able to get them in without any hole-making, the job looks professional, no wires hanging anywhere, everything tucked away. http://community.webshots.com/scripts/editPhotos.fcgi?action=viewall&albumID=253695439 i will try to get some snapshots of the elctrical work over this weekend (midterms ) Link to comment Share on other sites More sharing options...
Kaptan Posted January 18, 2005 Share Posted January 18, 2005 ^Can't view the picture - Error You do not appear to be the owner of this album. Link to comment Share on other sites More sharing options...
mmanus88 Posted January 18, 2005 Author Share Posted January 18, 2005 hmm works for me. anyways i can't fix it now, i will post images later this week. Link to comment Share on other sites More sharing options...
eavr4 Posted January 18, 2005 Share Posted January 18, 2005 hmm works for me. anyways i can't fix it now, i will post images later this week. Bro...your link is to the edit mode for your album....hence we can't access. The link in webshots are usually like this http://community.webshots.com/user/eavr4 where the last address is the nick you used for your album... Cheers! EA Link to comment Share on other sites More sharing options...
mmanus88 Posted January 18, 2005 Author Share Posted January 18, 2005 shit my bad here u go http://image30.webshots.com/30/9/62/39/253696239ZQZFyC_ph.jpg http://image30.webshots.com/31/9/64/19/253696419OBDsuh_ph.jpg http://image32.webshots.com/32/9/66/18/253696618QqMxzZ_ph.jpg http://image30.webshots.com/31/9/68/55/253696855cRjmmI_ph.jpg let me know if u cna see thes epics. over this weekend i will wash my car, wax, and have a slew of shots for u guys! Link to comment Share on other sites More sharing options...
fbi012 Posted January 18, 2005 Share Posted January 18, 2005 I see NOTHING. Link to comment Share on other sites More sharing options...
fbi012 Posted January 18, 2005 Share Posted January 18, 2005 DAM EA, nice pics. I noticed that you have rear sensors, did you install them or its an option there? If you did it, what brand did you use? Edit: one more thing, how much did you get the front lip spoiler for? is it a replica or OEM? Thanks. Link to comment Share on other sites More sharing options...
mmanus88 Posted January 18, 2005 Author Share Posted January 18, 2005 ok, my last attempt http://community.webshots.com/album/253695439WOgVex Link to comment Share on other sites More sharing options...
axis008 Posted January 18, 2005 Share Posted January 18, 2005 We're sorry! The Webshots page you have requested has either moved or no longer exists On another note, that is a sweet garage! Can you take a front picture with your HIDs? (Unless it's in the Webshots already... If that's the case then I'll just wait ) -ben Link to comment Share on other sites More sharing options...
fbi012 Posted January 18, 2005 Share Posted January 18, 2005 ok, my last attempt http://community.webshots.com/album/253695439WOgVex it worked but the HIDs section is empty? Link to comment Share on other sites More sharing options...
