1badlgt Posted April 11, 2008 Share Posted April 11, 2008 My right read window seems to have come loose, it has enough play in it to be leaking air, especially at highway speeds. I removed the door card and checked for enything loose and everything that i could see was tight. I searched but found little info besided the fact that others have had similar problems. Any insight would be great. Link to comment Share on other sites More sharing options...
1badlgt Posted April 13, 2008 Author Share Posted April 13, 2008 bump Link to comment Share on other sites More sharing options...
SpecBee Posted April 13, 2008 Share Posted April 13, 2008 ^ I have the same problems with the rear pass window. Took the door cover off and could not find any sort of window tensioner. The window has about 3/4" of play in the top where the drivers rear only has 3/8 - 1/2" of play. Would like an easy fix and avoid a dealer trip. Anyone have any service bulletins on this issue? Link to comment Share on other sites More sharing options...
1badlgt Posted April 14, 2008 Author Share Posted April 14, 2008 YOur problem sounds identical to mine, i wish i had an idea of what it could be, i really dont want to take the time to bring the car to the dealership. Link to comment Share on other sites More sharing options...
mtlonergan Posted April 8, 2012 Share Posted April 8, 2012 Okay, I got the same problem. Turns out its the motor bracket. All the bolts (4) are loose, in fact one was down in the doorwell and the other fell out while I was testing it. The 2 that were still intact were sliding up and down with the window... Scratching the paint. For the life of me, I can not get the holes to align.... WTF! Link to comment Share on other sites More sharing options...
