2008 C6 Corvette SQ Install for you guys :)
16psibrick
did this one a week or so back :)
well, after a long few weeks, i just got done with my first C6 corvett install. It was in all, an interesting car to work on, good in some sense installation wise, not so great in others.
Before i begin, i'd like to thank Leon and Eng for helping to tune the car :)
So here are the goals:
1. Good Sound quality
2. Classy design with a little bit of flash
3. hatch install able to be hidden out of sight.
those were the original goals...hatch usability was NOT a goal, nor was retaining the T-top storage. but i decided to added one more:
4. retain T top storage ability
equipment list:
headunit/processor: Alpine 205/701 combo
front stage: Seas Lotus reference 6.5" midbass, DLS Iridium 3" midrange, Seas reference tweeter
amplifiers: DLS ultimate A3(midbass) A2(midrange) A2(tweet) A6(subwoofers)
subwoofer: 3 x Image Dynamics ID8
lets get started:
The alpine 205 headunit is installed int he stock location, with door chime and onstar retention:
http://simplicity.elitecaraudio.org/vette1.JPG
http://simplicity.elitecaraudio.org/vette2.JPG
the alpine ipod cable is ran to the center arm rest:
http://simplicity.elitecaraudio.org/vette3.JPG
the Seas lotus tweeters were molded into the stock A pillar, aimed across at each other:
http://simplicity.elitecaraudio.org/vette4.JPG
http://simplicity.elitecaraudio.org/vette5.JPG
http://simplicity.elitecaraudio.org/vette6.JPG
http://simplicity.elitecaraudio.org/vette7.JPG
http://simplicity.elitecaraudio.org/vette8.JPG
and here are some build up pics of hte A pillars:
the factory vinyl was stripped off (a major pita) and the rings attached
http://simplicity.elitecaraudio.org/vette9.JPG
mold cloth streched and attached:
http://simplicity.elitecaraudio.org/vette10.JPG
after that was dry, the inside gap was filled with resin/glass combo so its rock solid:
http://simplicity.elitecaraudio.org/vette11.JPG
the pillars sanded and dampened:
http://simplicity.elitecaraudio.org/vette12.JPG
http://simplicity.elitecaraudio.org/vette13.JPG
and vinyled in factory matching vinly:
http://simplicity.elitecaraudio.org/vette14.JPG
http://simplicity.elitecaraudio.org/vette15.JPG
the midbass and mirdange reside in the factory locations in the door, i thought about trying out kick panel midrange, but there is virtually no room behind the kick and keeping hte deadpedal was a requirement.
first, the outter layer of metal is dampened:
http://simplicity.elitecaraudio.org/vette16.JPG
then the front panel dampened:
http://simplicity.elitecaraudio.org/vette17.JPG
then a mdf blocking baffle was cut out, the back side truck bed linered to prevent corrosion:
http://simplicity.elitecaraudio.org/vette18.JPG
and seals the big opening in the back....then, while i was waiting for the UPS man to deliver more dampening, i got bored and did some drawings lol...after looking at it, i think i should keep my day job and not become a cartooniest lol
http://simplicity.elitecaraudio.org/vette19.JPG
then the speaker baffles were made and sprayed on both sides:
http://simplicity.elitecaraudio.org/vette20.JPG
and attachd tot he door, and new speaker wires were ran into the door:
http://simplicity.elitecaraudio.org/vette21.JPG
http://simplicity.elitecaraudio.org/vette22.JPG
then finally, the lotus seas midbass was mounted:
http://simplicity.elitecaraudio.org/vette23.JPG
http://simplicity.elitecaraudio.org/vette24.JPG
the iridium 3 midbass i built a little baffle in the stock midrange cavity, and then dampened the baffle, the dampend was painted black so it wouldnt show through the midrange grille.
http://simplicity.elitecaraudio.org/vette25.JPG
and finally, the outter plastic door panel was smothered with dampening as well to prevent buzzing:
http://simplicity.elitecaraudio.org/vette26.JPG
and same goes for hte other side:
http://simplicity.elitecaraudio.org/vette27.JPG
http://simplicity.elitecaraudio.org/vette28.JPG
http://simplicity.elitecaraudio.org/vette29.JPG
and finally, two very solid doors that dont rattle or buzz at all :)
http://simplicity.elitecaraudio.org/vette30.JPG
http://simplicity.elitecaraudio.org/vette31.JPG
so...moving onto the hatch area...so here is the normal view with things hidden out of hte way, the carpet i have there is just a temp. solution, he is going to have a custom matching trunk mat made in the near future:
http://simplicity.elitecaraudio.org/vette32.JPG
remove the carpet,and here is what it looks like, the entire fake floor is in factory matching binyl, with three big cutouts and tw small ones, note corvette logo on a raised vinyl platform upfront and lettering on the covers:
http://simplicity.elitecaraudio.org/vette33.JPG
http://simplicity.elitecaraudio.org/vette34.JPG
http://simplicity.elitecaraudio.org/vette35.JPG
and here is the view of the front of the floor, with a piece of polished plexi with my logo secured on the front:
http://simplicity.elitecaraudio.org/vette36.JPG
http://simplicity.elitecaraudio.org/vette37.JPG
http://simplicity.elitecaraudio.org/vette38.JPG
pop off all the covers, and here is what it looks like. the theme that i had in my head is that of an engine, with two banks of "cylinder heads" flanking three downdraft carb with intakes. dont take it literally, but its the general theme :)
one the driver side, the A3 and A2, and on the passenger side, we have the A6 and A2, both sit in their own red vinly (factory matching) racks and are at a slight angle. all the wires in sight have chrome techflex and red shrink. the ground and poewr D-blocks are at the front, and the three ID8s sit ithe middle. the amps and D blocks have plexi over them as well, and the subs have an edge lit plexi border.
http://simplicity.elitecaraudio.org/vette39.JPG
http://simplicity.elitecaraudio.org/vette40.JPG
http://simplicity.elitecaraudio.org/vette41.JPG
http://simplicity.elitecaraudio.org/vette42.JPG
http://simplicity.elitecaraudio.org/vette43.JPG
http://simplicity.elitecaraudio.org/vette44.JPG
the platforms that the amps sit on, have an additional layer of edge lit plexi underneath, so with the leds turned on:
http://simplicity.elitecaraudio.org/vette45.JPG
http://simplicity.elitecaraudio.org/vette46.JPG
http://simplicity.elitecaraudio.org/vette47.JPG
http://simplicity.elitecaraudio.org/vette48.JPG
I also modified and raised the rear T-top mounting points so the stop still stows with the system in place:
http://simplicity.elitecaraudio.org/vette49.JPG
http://simplicity.elitecaraudio.org/vette50.JPG
its tight, but it clears the hatch with about 1/8" of an inch on both sides:
http://simplicity.elitecaraudio.org/vette51.JPG
IMo the car sound pretty good, Leon mentioned its one of hte better sounding sports cars he has heard...stage is very nice and high and suprisingly wide. midbass impact is one of hte strongest i have personally heard.
now here are some build up pics:
i trimmed out the stoccarpet in the back to gain as much space as possible, and then dampened the entire floor to block noise. i acutally ended up wtih an additioan 2" this way...quite a thick carpet :)
http://simplicity.elitecaraudio.org/vette52.JPG
now one of hte biggest challenges is that the entire floor of hte vette is some kind of plastic, so nothing can be screwed into it if you want it to last...so what i did was make a bottom platform board, and attached it securely to the few metal parts in the hatch area, namely hte crossbream behind the seats and the metal behind the wheel well. and then everyhting i build can attach themselves to this piece instead of hte floor:
http://simplicity.elitecaraudio.org/vette53.JPG
http://simplicity.elitecaraudio.org/vette54.JPG
here is test fitting the basic design:
http://simplicity.elitecaraudio.org/vette55.JPG
here is the jigsaw puzzle that is each amp rack well
http://simplicity.elitecaraudio.org/vette56.JPG
vinyled in red:
http://simplicity.elitecaraudio.org/vette57.JPG
and assembled, each well have their own crossflow fan pshing air over the amps and out the vent in the back
http://simplicity.elitecaraudio.org/vette58.JPG
the H701 rack whcih sits in the passenger side storage pocket:
http://simplicity.elitecaraudio.org/vette59.JPG
and here are the platforms the amps sit on,
http://simplicity.elitecaraudio.org/vette60.JPG
with a top vinly board and a bottom plexi piece that is edge lit:
http://simplicity.elitecaraudio.org/vette64.JPG
http://simplicity.elitecaraudio.org/vette61.JPG
and onto the d-block racks:
http://simplicity.elitecaraudio.org/vette62.JPG
http://simplicity.elitecaraudio.org/vette63.JPG
and the finished product, wired up:
http://simplicity.elitecaraudio.org/vette65.JPG
http://simplicity.elitecaraudio.org/vette66.JPG
http://simplicity.elitecaraudio.org/vette67.JPG
http://simplicity.elitecaraudio.org/vette68.JPG
the subbox:
http://simplicity.elitecaraudio.org/vette69.JPG
and the top fake floor and side pieces during construction:
http://simplicity.elitecaraudio.org/vette70.JPG
http://simplicity.elitecaraudio.org/vette71.JPG
plexi attached to the center piece and then leds secured and taped over to prevent light "leakage" :)
http://simplicity.elitecaraudio.org/vette72.JPG
http://simplicity.elitecaraudio.org/vette73.JPG
ready to be installed:
http://simplicity.elitecaraudio.org/vette74.JPG
http://simplicity.elitecaraudio.org/vette75.JPG
final shot of the trunk, all wired up, beofre hte floor goes on:
http://simplicity.elitecaraudio.org/vette76.JPG
and here are some panels i dampened along the way:
http://simplicity.elitecaraudio.org/vette77.JPG
http://simplicity.elitecaraudio.org/vette78.JPG
finally, construction of the covers, whcih ar two-piece each, with a vinyl top and suede bottom, raised vinyl lettering:
http://simplicity.elitecaraudio.org/vette79.JPG
the amp covers done:
http://simplicity.elitecaraudio.org/vette80.JPG
the d-block covers:
http://simplicity.elitecaraudio.org/vette81.JPG
and the sub grille, which is also two piece, with HD mesh secured to one and covered in grille cloth, and black suede on the other:
http://simplicity.elitecaraudio.org/vette82.JPG
http://simplicity.elitecaraudio.org/vette83.JPG
http://simplicity.elitecaraudio.org/vette84.JPG
