03subieroo Posted March 28, 2008 Share Posted March 28, 2008 i just pulled my spark wires to check to see if they needed replacement and ther was quite a bit of oil on the end of all 4 wires. wanted to kno if this is common on a subie or if i need piston rings or something along the lines of that. thanks its an 03 legacy l btw Link to comment Share on other sites More sharing options...
blackfang Posted March 28, 2008 Share Posted March 28, 2008 It is common for the valve cover gaskets and spark plug tube seals to leak. That is most likely where your oil leak is from. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
03subieroo Posted March 29, 2008 Author Share Posted March 29, 2008 It is common for the valve cover gaskets and spark plug tube seals to leak. That is most likely where your oil leak is from. yea, im puttin new wires and plugs on, looks like it needs it. thanks Link to comment Share on other sites More sharing options...
Bdubs Posted March 30, 2008 Share Posted March 30, 2008 yea, im puttin new wires and plugs on, looks like it needs it. thanks You realize he said the spark plug tube gaskets, not the plugs themselves, right? You'll only ruin a new set of plugs if you don't replace the those gaskets. Its a rather simple task. Hardest part is taking all the crap around the valve covers off to get to them. Link to comment Share on other sites More sharing options...
03subieroo Posted March 31, 2008 Author Share Posted March 31, 2008 yes i do, but i was indicating that it needed new plugs and wires too. the only thing i gotta remove thou is the washer bottle, two little screws. Link to comment Share on other sites More sharing options...
03subieroo Posted April 15, 2008 Author Share Posted April 15, 2008 got the valve cover job done, pretty simple, easy to do in half a day. Link to comment Share on other sites More sharing options...
ama0787 Posted March 31, 2011 Share Posted March 31, 2011 Do you remove motor mount bolts and raise the engine at all to get easier acess. I have 05 but the top of the heads is really cramped between the frame rails. I know it was tight when I changed my plugs. When I first got my supra I thought it was packed full and hard to work on under the hood. After getting the Suby and going single I realize it is a very roomy engine bay to work in Link to comment Share on other sites More sharing options...
burnout8488 Posted March 31, 2011 Share Posted March 31, 2011 I've done the VC's without having to move the motor around. Once the battery is out on an '05+ you've got plenty of room. Just put the car on ramps and you'll be able to get at the bottom Valve Cover bolts even easier from underneath. It's a cheap, rewarding repair, and the Fel-Pro gasket kit couldn't be any better. (Gaskets, tube seals, bolt seals(?)) Link to comment Share on other sites More sharing options...
thestratomaster Posted April 2, 2011 Share Posted April 2, 2011 Wonder if that's a common thing on 03's in particular. My brother's girlfriends 03 leggy had the same problem. Quite the mess in there Link to comment Share on other sites More sharing options...
