08leggy Posted March 26, 2008 Share Posted March 26, 2008 So I have had my powder coated wheels re balanced twice but my steering wheel still vibrates over 80 MPH could I need an alignment? Could the fact that the wheels are powder coated be a factor that they will never be balanced correctly? Link to comment Share on other sites More sharing options...
gianspi Posted March 26, 2008 Share Posted March 26, 2008 Check your lugnut torque. They should be at 80-90 ft/lbs. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
08leggy Posted March 28, 2008 Author Share Posted March 28, 2008 Ok so I re torqued them, it seems better but still does it around 90mph I was told that I probably had them balanced on a regular machine that only covers up to 60mph and need to have them balanced on a high speed balancer does this sound right? Link to comment Share on other sites More sharing options...
gusgusdude Posted March 28, 2008 Share Posted March 28, 2008 I had the same thing happen The garage that installed the new tires balanced them with the kind of weights that attach to the inside lip of the rim. Finally I took it to the dealer and he said all wheels were out of balance. He said that if they use the hammer on kind of weights then they are not balancing them at the exact spot that needs the weight. The dealer used stick on weights ... just like OEM Now the ride is perfect Link to comment Share on other sites More sharing options...
08leggy Posted March 28, 2008 Author Share Posted March 28, 2008 I have stick on weights inside the rim and the attachable ones on the inner part of the wheel. Link to comment Share on other sites More sharing options...
G.T.Subie Posted March 28, 2008 Share Posted March 28, 2008 Go to differnt shop. Denial is your best friend Link to comment Share on other sites More sharing options...
EL PAALO Posted March 28, 2008 Share Posted March 28, 2008 As long as the correct type of weight is used for the wheel, it doesn't matter which kind they use. It does sound like a balancing problem. You can try getting them road force balanced. Link to comment Share on other sites More sharing options...
