space_weazel Posted March 25, 2008 Share Posted March 25, 2008 My friend has a 98 or 99 2.2 Legacy that has just had the clutch replaced 4k ago, its started to as he describes it "slip in 1st and 2nd" he also says the clutch pedal has resistance from all the way at the top..... He thinks he needs to adjust the clutch cable, isn't it a Hydraulic? If it is a cable clutch wouldn’t slipping show in 4th and 5th first? Thanks for any advice or help sorting out this.... Link to comment Share on other sites More sharing options...
ehsnils Posted March 25, 2008 Share Posted March 25, 2008 Adjust the clutch - doesn't make a difference if it's hydraulic or a cable, it's the same problem and it is manifesting itself the same way regardless of the mechanics operating the clutch. In the meantime drive nicely so that you avoid glazing your clutch or you will have to replace it. Link to comment Share on other sites More sharing options...
space_weazel Posted March 26, 2008 Author Share Posted March 26, 2008 Thanks, anyone had a picture of the clutch arm and where it is on this model of legacy? Link to comment Share on other sites More sharing options...
ehsnils Posted March 26, 2008 Share Posted March 26, 2008 Somewhere on the upper end of the engine/gearbox casing close to the firewall. If it is a hydraulic clutch it may be that it's the pedal linkage that has to be adjusted since there is no adjustment on the slave cylinder for some reason that probably only a Subaru engineer can answer. Link to comment Share on other sites More sharing options...
space_weazel Posted March 27, 2008 Author Share Posted March 27, 2008 Thanks for the help everyone, he found it and has stared to get it sorted. Link to comment Share on other sites More sharing options...
