Tor Posted March 25, 2008 Share Posted March 25, 2008 Ok, I have done the search and there is a little discussion on the lack studs that come from the flange of the up pipe (yes, the up pipe I purchased did not come with the studs) but nothing about how to find new ones. I tried to salvage the ones on the stock up pipe, but there was no way of getting them out and usable even using BP and heat. I did get one out, but the threads were trashed! I called my local subaru dealer and auto parts stores and they do not show a p/n for the studs. The dealer says they come already in the stock up pipe. Anyone know a p/n for these studs? Or the size and thread pitch of the factory studs so I can go search a hardware store? In the mean time, my car sits on a lift Thanks in advance for any help you can offer. Link to comment Share on other sites More sharing options...
tommypenguin Posted March 25, 2008 Share Posted March 25, 2008 Here you go, they are pricey from the dealer..... http://www.flatironstuning.com/shop/pc-1420-991-subaru-oem-turbo-up-pipe-stud.aspx You might want to contact Revolutions Performance on here because they get oem parts for cheaper than invoice and might be able to save you a little money. Good luck. Link to comment Share on other sites More sharing options...
Tor Posted March 25, 2008 Author Share Posted March 25, 2008 Tommy, thanks so much for the huge help! Link to comment Share on other sites More sharing options...
rubberman Posted March 25, 2008 Share Posted March 25, 2008 The uppipe studs should be (M10 x 1.25). Most parts stores have them, NAPA does apparently. http://legacygt.com/forums/showthread.php?t=39943&page=2 Link to comment Share on other sites More sharing options...
VtspecB Posted March 25, 2008 Share Posted March 25, 2008 Yup, M10x1.25 sounds right. I just took it to my local Napa-like store and he led me to trays of all sorts of nuts and bolts. When you get them, just be sure to use thread lock on the uppipe threads. I believe I used the red thread lock which is the semi perminant high temp. my vBGarage Link to comment Share on other sites More sharing options...
GTTuner Posted March 26, 2008 Share Posted March 26, 2008 Shoulda bought the Indiva pipe, came with studs and nuts! I was impressed. Link to comment Share on other sites More sharing options...
