Legacy_GT_Pilot Posted March 11, 2008 Share Posted March 11, 2008 Can someone please explain to me what this table does and what other tables / values are impacted? Which values impact closed loop fueling? Which values impact open Loop fueling? Are these values reflected in the "AF Trim Immed" and "AF Trim Learned" when data logging is done? When I re-set the ECU through live tuning, these values don't get re-set. I'm trying to calibrate my MAF and would like to determine if and how these values are impacting my fuel trims. Thanks Dave ________ Chevy-Wiki.Com Link to comment Share on other sites More sharing options...
SeeeeeYa Posted March 12, 2008 Share Posted March 12, 2008 Can someone please explain to me what this table does and what other tables / values are impacted? Which values impact closed loop fueling? Which values impact open Loop fueling? Are these values reflected in the "AF Trim Immed" and "AF Trim Learned" when data logging is done? When I re-set the ECU through live tuning, these values don't get re-set. I'm trying to calibrate my MAF and would like to determine if and how these values are impacting my fuel trims. Thanks Dave Good question..... one I need to know more about myself. I looked at my tune and all I had was '0's' in those cells. I figured maybe I had to be connected to the car so I went down and hooked it up. That gave me some more cells...... all populated with zeros. I din't start the car because it is late and it didn't make any sense it would make a difference. I tried to help, but ended up with some of my own questions instead. What is in the cells on yours when you are disconnected from the ECU? And what is in the cells when you are in communication with the ECU? Screenshots are nice. Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted March 12, 2008 Author Share Posted March 12, 2008 When in "Live Tuning" mode, you can select the table and see the different values. I've had all zeros, and at other times had values populated (-3 in the first cell, -0.10 in the second). I have now realized the values clear after re-setting the ECU - you just need to exit live tuning and connect again to refresh the values. Dave ________ bondage girl Cam Link to comment Share on other sites More sharing options...
SeeeeeYa Posted March 12, 2008 Share Posted March 12, 2008 When in "Live Tuning" mode, you can select the table and see the different values. I've had all zeros, and at other times had values populated (-3 in the first cell, -0.10 in the second). I have now realized the values clear after re-setting the ECU - you just need to exit live tuning and connect again to refresh the values. Dave Also, I'd imagine, hitting F5 would refresh it? I'll have to keep an eye on this now. I'm always checking the Knock Learning. This will be another. Link to comment Share on other sites More sharing options...
squishyface Posted March 12, 2008 Share Posted March 12, 2008 I just had a major 1 hour course with Sean @ Rallitek yesterday about this during my street tune. He and I will be getting together today. I will get a 24 hour refresher and would be glad to update. Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted March 12, 2008 Author Share Posted March 12, 2008 That would be great. Thanks. I just had a major 1 hour course with Sean @ Rallitek yesterday about this during my street tune. He and I will be getting together today. I will get a 24 hour refresher and would be glad to update. ________ Depakote lawyers Link to comment Share on other sites More sharing options...
