Mitch Posted March 3, 2008 Share Posted March 3, 2008 06 LGT Ltd. Wagon. Stock HU. I put in Polk DB651s front and rear doors. 150Hz Bassblockers on rear speakers Installing a 250w Basslink II tomorrow w/35w x 4 back to the door speakers. When I turn up HU to 18 or so. All speakers shut down. If I have balance set to +9 rear I cant turn it up past 9 If I have it set up +9 Front It'll turn up to 26. As I start to Fade to the rear I get to about +4 Front and all speakers cut out again. I turn it down and shut off the car. Restart the car and it works fine. Until I turn it up or fade balance to the rear. Any ideas what the problem could be? If I'm going faster than you, Move Right. Link to comment Share on other sites More sharing options...
Zimm Posted March 3, 2008 Share Posted March 3, 2008 Shorted wire to one of the speakers. The stereo is protecting itself when the current draw gets too high due to a short somewhere.. Check all you speakers connectors for shorts to the chassis/themselves. Link to comment Share on other sites More sharing options...
Mitch Posted March 3, 2008 Author Share Posted March 3, 2008 Did/ will do again though. Thanks. would it be more probable that it's a rear speaker then? Since it cuts out more when balance/low volume is to the rear? Fixed If I'm going faster than you, Move Right. Link to comment Share on other sites More sharing options...
