gianspi Posted February 22, 2008 Share Posted February 22, 2008 I'm so happy I tackled this project. Every GPS install I could find lost the door. I really wanted to keep the stock appearance to guard against thiefs. I took the cubby out and dremeled the top and bottom to fit the GPS. I then applied some electrical tape to the bottom part to create a "sack" for it to fit in. I still want to smooth out the edges but all in all I am very proud of myself. This is my first time doing anything like this. http://gsent.org/gpsfits.jpg There is a shadow caused by the flash. In real life the screen is bright and you can see everything perfectly! http://gsent.org/gpscloseup.jpg Oh yea, and $0 spent on this project ________________ How-to guide here! enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
s car go Posted February 22, 2008 Share Posted February 22, 2008 This is the route I thought about taking if I can't get a good hole cut in my cubby door. Looks good and most importantly, as you said, helps prevent theft. Link to comment Share on other sites More sharing options...
lossol Posted February 22, 2008 Share Posted February 22, 2008 Whoa great Idea! Do you have any pics of the hole you had to cut? VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
croll326 Posted February 22, 2008 Share Posted February 22, 2008 nice! do you have step by step pics? nice job. Link to comment Share on other sites More sharing options...
gianspi Posted February 22, 2008 Author Share Posted February 22, 2008 I wasn't expecting it to come out as good as it did, so I didn't take any pictures. I am going to remove my radio to install the aux-in solder kit, so when I do that (probably next weekend), I will remove the cubby and show how I drilled it. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
Claw Posted February 22, 2008 Share Posted February 22, 2008 Did you relocate the antenna? Does the unit work with the antenna in the cubby? Thanks, great work! Link to comment Share on other sites More sharing options...
rookie ddz Posted February 23, 2008 Share Posted February 23, 2008 I second about the antenna. What model nuvi also. I think I'm in the market for GPS. More pics. Link to comment Share on other sites More sharing options...
starhm Posted February 23, 2008 Share Posted February 23, 2008 subscribed... Link to comment Share on other sites More sharing options...
gianspi Posted February 23, 2008 Author Share Posted February 23, 2008 Did you relocate the antenna? Does the unit work with the antenna in the cubby? Thanks, great work! The antenna seems to work perfectly fine inside of the cubby. I squeezed together a plastic shopping bag into a tiny ball and wrapped it in electrical tape. I taped this ball behind the antenna so it couldn't snap closed when hitting a hard bump. The model I have is the Nuvi 360. I'll do a complete how-to guide next weekend. Also if you close the door and re-open it, the GPS is a slanted slightly backwards about 5 degrees. If you give it a tap with your finger it snaps back into place just fine. This is because the cubby door pushes down on the GPS when re-opening it. It's no big deal though; it only take 3 seconds. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
TheSoCalledJohn Posted February 28, 2008 Share Posted February 28, 2008 Great install! I just got a Nav system and I was thinking of making up a bracket to attach to the upper part of the left A/C vent, but this may be even better! I'll have to find another place to put my sunglasses though... Did you hard wire the charging cable to the cigarette lighter, or are you just going to remove the Nav unit when you need to charge it? Link to comment Share on other sites More sharing options...
subiedude Posted February 28, 2008 Share Posted February 28, 2008 This is exactly what I wanted to do, but my unit is too big (I have the TomTom One XL). And the power button is on the top of the unit. Link to comment Share on other sites More sharing options...
CzarDestructo Posted February 28, 2008 Share Posted February 28, 2008 FYI, the widescreen Nuvi are wider but not as tall height wise. As a result they fit inside the cubby perfectly if the door is removed. If you set it back far enough you could retain the door and not need to dremel anything. I almost sold my current Nuvi to get a widescreen and do this but decided my Sirius radio would look better in there since it matched all the dashboard colors. http://img2.freeimagehosting.net/uploads/a413161bb0.jpg Excuse the pic, its a little uneven but I've fixed it. I need to just get one of those blank cubbypod inserts so I can cut and mold the radio into it to clean up the look a bit. Link to comment Share on other sites More sharing options...
bassrun Posted March 23, 2008 Share Posted March 23, 2008 This is exactly what I wanted to do, but my unit is too big (I have the TomTom One XL). And the power button is on the top of the unit. Isn't the power button on the top of the Nuvi? So I guess I don't understand how to turn it on and off.... I'd love to see/read about the details of the installation. Link to comment Share on other sites More sharing options...
lossol Posted March 23, 2008 Share Posted March 23, 2008 My 200W nuvi turns off and on automatically with when the cig lighter votlage comes up on ignition. Opon loss of power it asks you if it wants to shut down or just shuts down in 30 secs. nice feature really. VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
gianspi Posted March 28, 2008 Author Share Posted March 28, 2008 How-to guide here! enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
SunburnNYC Posted March 28, 2008 Share Posted March 28, 2008 LCD soundsystem! NICE! http://img2.freeimagehosting.net/uploads/a413161bb0.jpg Link to comment Share on other sites More sharing options...
