Legacy Spec.B / WRX pedals for 2008
qwertyb22
Posted
So, I purchased WRX pedals from MastroWRX and was pumped to put them on. Unfortunately, as it turns out they will not fit on a 2008 car. The dead pedal, clutch and brake all fit fine, but 07-08s have a one-piece gas pedal. I searched around and couldnt find a part number for one that would work on 08s, but hey, the 08 Spec.Bs have the sport pedals, so they must exist, right? I ended up getting the part number from Liberty Subaru, and I've got the pedal on the way. The part number is 36010AG150 and its the whole throttle-by-wire assembly for the Spec.B. Just thought I'd post the part number in case anyone else was trying to find it. I contacted Mastro WRX, and they're checking into making it available as a package with the other pedals for the 08 cars.
Posted
Yeah, thats the catch. The gas pedal alone was $104 I believe, and that was from Liberty which discounts the MSRP. Looking at the pedals, I dont think you can modify the WRX pedal. If you look at the instal instructions for the WRX pedals (on this site), theres a PITA pin that you have to pound out. The 08s have a one piece assembly so there is no pin - essentially its all one piece vs. 2 pieces and a pin.
Posted
BTW the part number for the clutch and brake is 36024FA010, in case you wanted to buy the set. You have to get the dead pedal aftermarket though, check Mastro WRX.
