BLKGT5 Posted February 20, 2008 Share Posted February 20, 2008 I get some vibration in my steering wheel starting at 45MPH and UP. What would cause this? It seems to be more noticeable when colder. I've had two different places rotate and balance my wheels. Could bad drive shafts cause this? I've recently had my clutch replaced, would that effect anything if they didn't place the shaft back in the same position? How much are new drive shafts? Thanks. Link to comment Share on other sites More sharing options...
cnote Posted February 20, 2008 Share Posted February 20, 2008 Not an expert by any means, but I believe if you are experiencing the vibrations at certain mph readings it could be your rotors...though this is usually during breaking. Also, might be something as simple as a wheel balance, should probably check there first Link to comment Share on other sites More sharing options...
bobo69 Posted February 20, 2008 Share Posted February 20, 2008 tires out of round/flat spotting? Link to comment Share on other sites More sharing options...
SpeedNeeder Posted February 21, 2008 Share Posted February 21, 2008 My car used to get wobbly when driving over 80 on the interstate. It went away though, I think it was the brake pads. My other car is a 1993 Chevy S-10 Tahoe! (Currently being driven to failure by my nephew) Link to comment Share on other sites More sharing options...
