Abs
Posted
it seems the bias to the rear brakes is a bit much on my 08....coming to a stop the front and rear will lock up and i just slide....i mean...not that i mind it...i really hate abs....but never had another car with abs even let me attempt to lock up the tires and slide. anyone else get this?
Posted
the rear locks up easy because your suspensionis soft. when you brake, all the weight goes to the front of the car and the car nose dives. this takes weight of the rear making it easy to lock up the rear brakes. Generally, the LGT could benefit from more bias to the rear brakes. more bias to the rear will actually prevent the car from nose diving as much under braking. Better tires and stiffer suspension will also remedy this.
