Wolfden13 Posted October 28, 2019 Share Posted October 28, 2019 Thank you for your service My Zommie brother! I say that with ultimate respect! I'll try that but it seems to be within a 11mm and 1/2" I have a torque driver but felt uncomfortable utilizing it. I'll use the method you stated I have a 12" schedule 40 pipe I use for a breaker bar when my 1/2" breaker Craftsman bar wont fit due to height to floor clearance. Sincerely appreciate your advise. Thank you! Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
SubOperator Posted October 29, 2019 Share Posted October 29, 2019 Related inquiry. I just did a rear hub and the wheel speed sensors mount was broken and held in place by an additional washer. It seems like a loose fit, is there supposed to be some kind of seal or something on that? I feel like gunk could work down in there... Washer is fine to hold the sensor in place, there is no load on it. Your gunk concern is valid, I would take the sensor out, clean the sensor and the channel it is going in, and then apply a bit of silicone/seal maker to the top rim of the sensor, or knuckle surface where sensor touches down. Dirt getting in knuckle mounting channel where sensor sits definitely makes for difficult removal, I went through it with wife's Tribeca this summer. Rear sensors are mounted upside down, with no real way to seal the channel. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
