jcSKYhigh Posted February 9, 2008 Share Posted February 9, 2008 I just put in new D.P. and a U.P. and my car rattles when i turn left. Which one do you guys think is causing this problem? Link to comment Share on other sites More sharing options...
whitetiger Posted February 9, 2008 Share Posted February 9, 2008 you need to describe the rattleing sound more. where is it comming from and what type of rattle is it. like a dash rattle, a heatsheild rattle....ect. where is the sound comming from? Help us help you. Link to comment Share on other sites More sharing options...
jcSKYhigh Posted February 9, 2008 Author Share Posted February 9, 2008 The rattling sound is coming from the passenger side. The rattling kind of vibrates like two things are hitting each other. Hope that helps. Link to comment Share on other sites More sharing options...
whitetiger Posted February 9, 2008 Share Posted February 9, 2008 did you do the install yourself? check the clearance between the DP and the firewall. ive seem some DPs get ver close to hitting it. also check the turbo heatsheild to se if its secured properly. Link to comment Share on other sites More sharing options...
jcSKYhigh Posted February 9, 2008 Author Share Posted February 9, 2008 I did it myself, i guess i either got a crappy DP or i just installed it wrong. I remember the DP being pretty damn close to the firewall. Should i replace the DP or is there anyway i can just tweak it to get more clearance? THANKS!!! Link to comment Share on other sites More sharing options...
whitetiger Posted February 9, 2008 Share Posted February 9, 2008 Which DP did you have? is it the perrin 1pc catless? Link to comment Share on other sites More sharing options...
jcSKYhigh Posted February 10, 2008 Author Share Posted February 10, 2008 Invidia downpipe Link to comment Share on other sites More sharing options...
ehsnils Posted February 10, 2008 Share Posted February 10, 2008 The rattling sound is coming from the passenger side. The rattling kind of vibrates like two things are hitting each other. Hope that helps. Check the contents of the passenger door storage first... Link to comment Share on other sites More sharing options...
SpecBee Posted February 10, 2008 Share Posted February 10, 2008 Did you inventory your wrenches and sockets when done? One could be missing... Link to comment Share on other sites More sharing options...
SlightlyEvil Posted February 11, 2008 Share Posted February 11, 2008 i have the invidia DP and mine doesn't slap the firewall at all, even under engine loading and twisting (if you bolted it to the tranny properly it won't at least). Check the bracket that attaches it to the tranny (I'm assuming you've got MT not AT). Check the bolts are all securely tightened at the DP>turbo flange. Check any bolts in any bungs you may have (not sure if the AT DP has a wideband bung that's bolted, I had one put in mine when it was tuned and my bolt rattled till I put a washer on it.) Weird that it only makes it when turning left, but seems the LGT makes all sorts of weird sounds... its like an old man, it makes weird noises when it rains. Link to comment Share on other sites More sharing options...
tommypenguin Posted February 11, 2008 Share Posted February 11, 2008 Did you also check to make sure no heat shield is resting against the dp? Link to comment Share on other sites More sharing options...
jcSKYhigh Posted February 11, 2008 Author Share Posted February 11, 2008 i contacted the seller and he says that he'll replace it and see if its the problem. I'll post again when i find out whats the problem. Thanks for all the help guyz. I feel home already w/ my new subaru! Link to comment Share on other sites More sharing options...
