absolutsnwbrdr Posted February 9, 2008 Share Posted February 9, 2008 I wanted to disable the DRL on my 06 Limited so I went to pull the plug for the DRL's, and accidently pulled the wrong plug out. I started the car and the Check Engine light was on and the Cruise indicator is flashing. I turned the car off, climbed back underneath the dash plugged back in whatever I unplugged and found the correct plug. DRL's are off, but my check engine light is still on. Ideas? Link to comment Share on other sites More sharing options...
whitetiger Posted February 9, 2008 Share Posted February 9, 2008 disconnect the ground cable from the battery for a couple min, thne put it back on. it will clear the CEL out. Link to comment Share on other sites More sharing options...
absolutsnwbrdr Posted February 9, 2008 Author Share Posted February 9, 2008 good to go... thanks! hmmm... wonder what the first cable that I unplugged was.... oh well! Link to comment Share on other sites More sharing options...
Jon Kanas Posted February 13, 2008 Share Posted February 13, 2008 On either my '05 or '06 XT's, I can get the Cruise and Check Engine flashing by accidentally hitting the cruise button when starting the car. I'm not sure how I manage to do this, but I do it with some regularity. If I restart the car several times (5 or 10; I don't remember which) it resets the trouble code and everything returns to normal without losing the presets on the radio, climate etc. Link to comment Share on other sites More sharing options...
