croll326 Posted February 9, 2008 Share Posted February 9, 2008 The trans is out for some warranty work. Bad bearings the dealer is saying. Im getting a new OEM clutch and spec LWFW. does anyone have this set up? if so how is it. I got it from the king of parts for $625 Link to comment Share on other sites More sharing options...
chenc544 Posted February 9, 2008 Share Posted February 9, 2008 Which bearing? The TOB? If so what were the symtoms? I'm trying to convince my dealer I need a new TOB. Link to comment Share on other sites More sharing options...
croll326 Posted February 9, 2008 Author Share Posted February 9, 2008 symptoms- on cold start up i would press the clutch to start the car and when i let off the clutch - leaving the car in neutral - there would be a wierd squealing noise that would only go away when i pressed the clutch in again. it would only last about a minutre until the car was warm. the car would have to sit for about 8 hours before it would make the noise again. i was basically a pain in the butt at the dealer until they did something. they heard the noise and tried giving me the run around but i didnt let them. be persistant. let me know if you have any other questions. they are saying its one of 5 bearings in the trans. i said it was the TOB but they refuse to acknowledge the fact that it is or isnt so who knows. the new clutch kit from the KOP inclues the TOB so it will make me feel better to have a new one even if it wasnt the problem. Link to comment Share on other sites More sharing options...
magnus617 Posted February 9, 2008 Share Posted February 9, 2008 i fail to see why any bearings in the trans would stop squealing when you would push the pedal in. i would also think that a tob would be a lot easier to replace than a bearing inside the trans. maybe point that out to them when you take it in, if you haven't done so all ready. never, under any circumstances, take sleeping pills at the same time as a laxative. Link to comment Share on other sites More sharing options...
mccorry Posted February 9, 2008 Share Posted February 9, 2008 I have the same problem. It is the throw-out bearing for the pressure plate. Mine does it when it is cold and the clutch is held in all the way. Link to comment Share on other sites More sharing options...
croll326 Posted February 10, 2008 Author Share Posted February 10, 2008 mine stopped when the clutch was pushed in at all. Link to comment Share on other sites More sharing options...
croll326 Posted February 10, 2008 Author Share Posted February 10, 2008 ok back to the opinions of the spec LWFW ? Link to comment Share on other sites More sharing options...
