Legacy05 Posted April 19, 2008 Share Posted April 19, 2008 ^ it really does depend on what you do, if you don't track your car the stock clutch will last quite a bit longer, I had to change mine out at 69k miles, and that was only because of my throw-out bearing going bad. Link to comment Share on other sites More sharing options...
Mr. Ed Posted April 19, 2008 Share Posted April 19, 2008 ^ it really does depend on what you do, if you don't track your car the stock clutch will last quite a bit longer, I had to change mine out at 69k miles, and that was only because of my throw-out bearing going bad. the stock clutch was ran at the track once... and that was when it had already been determined to be on it's way out.... with all the time I spent reading the clutch posts I'd say it's hit or miss ...but there have been a number go out under conservative use with no track time Link to comment Share on other sites More sharing options...
sportwagon Posted April 23, 2008 Share Posted April 23, 2008 hmmmm.... I'm at exactly 69K now! Link to comment Share on other sites More sharing options...
