foerster Posted January 17, 2005 Share Posted January 17, 2005 I ended up getting the Proxes 4's, not Neros, but I get the rumblies for the first few miles too. Pressure is set a couple pounds over spec, but temps have been pretty cold so it still flats out until they warm up a bit. Link to comment Share on other sites More sharing options...
SUBE555 Posted January 17, 2005 Share Posted January 17, 2005 I have the Proxes 4's and I run 41F/38R and I don't have any problems with flat spots and that includes sitting outside every here and there even in below-zero temps. I think a bit of it is due to the pressures I run. Sure it's a little more rugged, but it provides excellent feedback as well as better fuel mileage, even if you do get a little more road noise. Link to comment Share on other sites More sharing options...
Scooter Posted January 17, 2005 Share Posted January 17, 2005 Update: had my PZero's for a week and a half now, with no flat-spot problems - and it got down to 5 degrees last night. Brrrr. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
jaycee Posted January 20, 2005 Share Posted January 20, 2005 Same here - I've had mine for a couple of weeks now - had the car sitting outside in the parking lot at work for 14+ hours in single digit weather and no flat spots. Link to comment Share on other sites More sharing options...
mmm def Posted January 21, 2005 Share Posted January 21, 2005 Me too- couple of weeks, some nights inside some nights outside (5 F ) No flat spots. Link to comment Share on other sites More sharing options...
scubie02 Posted January 21, 2005 Share Posted January 21, 2005 well, its been 20 belowish here for the past several weeks, and I can say that the stock re-92's flat spot. But then most tires do when its that cold, to varying degrees. Link to comment Share on other sites More sharing options...
