bitter-bert Posted February 5, 2008 Share Posted February 5, 2008 Okay, guys, I did a search on this, and yes, I know what the problem is. Just wondering if anyone actually had it fixed because I'm not interested in disabling it. It's with the clutch neutral safety switch (or that's what I think it's called). Anyways, while at work, I tried to start my car, clutch pushed all the way in, tried to crank it, nothing, but accessories and what not working, fan going like there's no tomorrow. So, even though knowing the battery wasn't discharged or anything, I still cleaned up the terminals and what not. Tried to start it again... nothing. I call Timmons Subaru over in Long Beach, they go down a list of things, including if I had the clutch pushed all the way. (which I did). So they go on with, try kicking the clutch while starting the car see if it'll crank. Eventually it did crank after a few tries. Now for the question, anyone else run into this problem? And if they decided to get it fixed instead of doing the disabling mod? Also how much you think it'll cost to change? Thanks guys. -Bert Link to comment Share on other sites More sharing options...
SpecBee Posted February 5, 2008 Share Posted February 5, 2008 Maybe it was a gremlin??? dunno, but thanks for the tip... Is there anyway to search for TSBs for Subies? That's the first place I would look... Link to comment Share on other sites More sharing options...
momomax Posted February 28, 2008 Share Posted February 28, 2008 same thing has happened to me. I thought it was some sensor not sensing the clutch is being depressed. It occurred to me that my aftermarket rubber floor mat was keeping my clutch pedal from going all the way down. A simple adjustment of floor mat placement seemed to be the cure. good luck Link to comment Share on other sites More sharing options...
SBT Posted February 28, 2008 Share Posted February 28, 2008 Okay, guys, I did a search on this, and yes, I know what the problem is. Just wondering if anyone actually had it fixed because I'm not interested in disabling it. It's with the clutch neutral safety switch (or that's what I think it's called). Anyways, while at work, I tried to start my car, clutch pushed all the way in, tried to crank it, nothing, but accessories and what not working, fan going like there's no tomorrow. So, even though knowing the battery wasn't discharged or anything, I still cleaned up the terminals and what not. Tried to start it again... nothing. I call Timmons Subaru over in Long Beach, they go down a list of things, including if I had the clutch pushed all the way. (which I did). So they go on with, try kicking the clutch while starting the car see if it'll crank. Eventually it did crank after a few tries. Now for the question, anyone else run into this problem? And if they decided to get it fixed instead of doing the disabling mod? Also how much you think it'll cost to change? Thanks guys. -Bert Probably 1 of 2 things (possibly more) Clutch out switch (above the pedal), out of adjustmentIgnition switch gremlinI don't think that the transmission neutral switch has any bearing on this as you can start the engine with the car in any gear, as long as the clutch pedal is depressed - so I refer back to item number one above. If it is the switch, you should be able to change that out yourself. I'll check part numbers and give you an estimate on cost. I'm also going to peruse the shop manual troubleshooting guide and see if there is anything else to check. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted February 28, 2008 Share Posted February 28, 2008 Here's an Engine Failure to Start check list and troubleshooting guide. This is likely the checklist that Timmons went through, or at least a part of it. SBT16 - Diagnostics For Engine Starting Failure.pdf - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
