cmraman Posted February 1, 2008 Share Posted February 1, 2008 Which intake would you recommend.. the K&N Typhoon or the STI intake for the 2.5 turbo. I should add i have a 2005 Outback xt with Auto. Thanks, Link to comment Share on other sites More sharing options...
bgray Posted February 1, 2008 Share Posted February 1, 2008 Well by searching you will find that no one really suggest using an intake unless you need one for a biiger turbo, or you are having the car dyno tuned. However, if you want one, the SPT one is apprently not the way to go. it heats up radically at idle and increases iat, which hot air in is no good. typhoon is the way to do it Link to comment Share on other sites More sharing options...
RaGe Posted February 1, 2008 Share Posted February 1, 2008 stock. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
cmraman Posted February 1, 2008 Author Share Posted February 1, 2008 Well by searching you will find that no one really suggest using an intake unless you need one for a biiger turbo, or you are having the car dyno tuned. However, if you want one, the SPT one is apprently not the way to go. it heats up radically at idle and increases iat, which hot air in is no good. typhoon is the way to do it Thanks. but what is the difference if it is the stock turbo or not? Link to comment Share on other sites More sharing options...
RaGe Posted February 1, 2008 Share Posted February 1, 2008 easy answer. the stock intake system is capable of handling up to 400hp. it is a well flowing system. just save yourself some heartache. if you do not get tuned for a CAI your car will run like pure shit and it will do more harm than good. simple. dont believe me then search around. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
cmraman Posted February 1, 2008 Author Share Posted February 1, 2008 easy answer. the stock intake system is capable of handling up to 400hp. it is a well flowing system. just save yourself some heartache. if you do not get tuned for a CAI your car will run like pure shit and it will do more harm than good. simple. dont believe me then search around. Forgive for my ignorance, I would have the car tuned for the intake? CAI? Link to comment Share on other sites More sharing options...
RaGe Posted February 1, 2008 Share Posted February 1, 2008 CAI=Cold air intake. you WILL have to get the car professionally tuned yes. if you dont your car will run like shit. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
cmraman Posted February 1, 2008 Author Share Posted February 1, 2008 CAI=Cold air intake. you WILL have to get the car professionally tuned yes. if you dont your car will run like shit. Thanks for the advice. Will the Cobb programmer help with this? I was thinking about this as well. Link to comment Share on other sites More sharing options...
RaGe Posted February 1, 2008 Share Posted February 1, 2008 no it will not help. you will actually have to take it to a tuner and get tuned for it. A COBB AP ( Access Port ) will not do anything for what you are wanting. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
cmraman Posted February 1, 2008 Author Share Posted February 1, 2008 no it will not help. you will actually have to take it to a tuner and get tuned for it. A COBB AP ( Access Port ) will not do anything for what you are wanting. If I tune the car, then will I see gains with the Access port? Link to comment Share on other sites More sharing options...
dtmenace Posted February 1, 2008 Share Posted February 1, 2008 you need 1) a tuner & (not or) 2) an accessport or software to modify your car's computer. the CAI is not necessary to make HP gains, the accessport is. there is a thread... let me dig it up. Link to comment Share on other sites More sharing options...
BDII Posted February 1, 2008 Share Posted February 1, 2008 If I tune the car, then will I see gains with the Access port? Talk to TDC or PDX tuning and see if they can email you map for an intake. Problem solved /thread Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
cmraman Posted February 1, 2008 Author Share Posted February 1, 2008 Talk to TDC or PDX tuning and see if they can email you map for an intake. Problem solved /thread Thanks, I'll look into this. Have you used the Access port? Is it worth the money for the gains? Link to comment Share on other sites More sharing options...
BDII Posted February 1, 2008 Share Posted February 1, 2008 Worth every Penny Stage 1 will be pleasantly suprising to you. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
cmraman Posted February 1, 2008 Author Share Posted February 1, 2008 Worth every Penny Stage 1 will be pleasantly suprising to you. What car do you have? is it pretty much stock? what mods have you made? Link to comment Share on other sites More sharing options...
cmraman Posted February 1, 2008 Author Share Posted February 1, 2008 What car do you have? is it pretty much stock? what mods have you made? What's a good source for this? Link to comment Share on other sites More sharing options...
BDII Posted February 1, 2008 Share Posted February 1, 2008 Click on my VBgarage. Also, check out this thread: http://legacygt.com/forums/showthread.php?t=67940 Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
dtmenace Posted February 1, 2008 Share Posted February 1, 2008 you have to be real, right? : pinches_self : ...ouch... if you use the search feature located @ the top right of each page, i think you may find what you are looking for. these are some of the places you should start.... http://legacygt.com/forums/showthread.php?t=67940 http://legacygt.com/forums/newthread.php?do=newthread&f=40 & only after those threads should you look here: http://legacygt.com/forums/forumdisplay.php?f=12 Link to comment Share on other sites More sharing options...
SubLGTaru Posted February 1, 2008 Share Posted February 1, 2008 Get a drop in replacement air filter....better mod than a CAI. Link to comment Share on other sites More sharing options...
BDII Posted February 1, 2008 Share Posted February 1, 2008 Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
tommypenguin Posted February 1, 2008 Share Posted February 1, 2008 Question for you guys, I am planning on purchasing a K & N intake because I have every other bolt on except for an intake and am getting protuned in february. I know the gains are minimal, but this is my first turbo car and I have learn to love all the sounds associated with it. My tuner is 1 1/2 hour away, I will have to take the highway to get there probably be at 3k rpm most of the drive, ideally I wanted put the intake on in my garage the morning before I head out. But I could get to the tuners early and do the install fairly quickly in the parking lot when I get to the tuner. Question for you is, how bad would it be for me to make the 1 1/2 hour drive on the highway with the intake untuned on a cobb stage 2 base map? Haha after rereading my post I think I already know I should just put on the intake in the parking lot of tuner. Link to comment Share on other sites More sharing options...
RaGe Posted February 1, 2008 Share Posted February 1, 2008 your answer is correct. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
BDII Posted February 1, 2008 Share Posted February 1, 2008 Question for you guys, I am planning on purchasing a K & N intake because I have every other bolt on except for an intake and am getting protuned in february. I know the gains are minimal, but this is my first turbo car and I have learn to love all the sounds associated with it. My tuner is 1 1/2 hour away, I will have to take the highway to get there probably be at 3k rpm most of the drive, ideally I wanted put the intake on in my garage the morning before I head out. But I could get to the tuners early and do the install fairly quickly in the parking lot when I get to the tuner. Question for you is, how bad would it be for me to make the 1 1/2 hour drive on the highway with the intake untuned on a cobb stage 2 base map? Haha after rereading my post I think I already know I should just put on the intake on in the parking lot of tuner. you'll be fine. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
fonts Posted February 3, 2008 Share Posted February 3, 2008 Get a drop in replacement air filter....better mod than a CAI. Agree with the comments about the CAI. Save the $250-300 that you would pay for a CAI and get a replacement drop in panel filter like the Perrin or AVO. Link to comment Share on other sites More sharing options...
