FJuan Posted January 26, 2008 Share Posted January 26, 2008 I've been driving on my new uppipe for about 2 months now, 2 weeks ago I connected the mufflers back together from being hoghaust, wanted some piece and quite for awhile. Then I notice the following day while under full accelleration I started to hear a whistling sound coming from under the hood at 5000 RPMs. Not talking about a whoooooosh sound, more like a high pitch whistle. Only happens at around 5k RPMs under full accellerations. Is this normal to hear with a gutted uppipe and panel filter? Or could there be an exhaust leak? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
dynamic80 Posted January 26, 2008 Share Posted January 26, 2008 More than likely an exhaust leak. I had just checked mine and it was from header to up-pipe connection. Lift her up and check her out. I'm guessing you heat cycled it? Link to comment Share on other sites More sharing options...
qikslvr Posted January 26, 2008 Share Posted January 26, 2008 About a 95% chance it a leak between the manifold an UP. That union leaks A LOT! Let's kick this pig! Link to comment Share on other sites More sharing options...
FJuan Posted January 26, 2008 Author Share Posted January 26, 2008 I was checking it out last night and notice the rubber gasket between the BPV to I/C was missing and saw some grime around the area. Tried to do a quick fix by using silacone, until I can get a new gasket new week. Didn't work well and cause the sound to increase more. Guess I'll have to take it easy until I get the new gasket. Plus I'll take a look at the flang by the uppipe just to make sure. Thanks for the advice. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
DoubleM Posted January 28, 2008 Share Posted January 28, 2008 ugh, I still have a little sound from my uppipe. The damn thing won't stop leaking, I'm using an MR flex uppipe with perfect flanges, and TWO OEM gaskets in there to seal it up. I can't see how it would leak. Mine only makes the sound under moderate to heavy acceleration. Sometimes it makes a noise, sometimes it doesn't. I'm hoping it's because of the cold and will go away when it warms up:rolleyes: Sorry for the little rant. I hope you have better luck finding a remedy for your leak. For now, I must live with an angry little raccoon in my turbo. Link to comment Share on other sites More sharing options...
