Richard B. Posted January 22, 2008 Share Posted January 22, 2008 hawk pads aren't bedded in yet, but let me tell you. THIS is how it should have come from factory. i did a 75-40 mph test and it was smooth. no shaking like it normally does with stock pads. it's got bite right now which i think will go away after i bed them. solid smooth braking. now i just need to do a 100-50mph test. this should be done with new tires. should be done before an ap imo. put it very high on the list. Link to comment Share on other sites More sharing options...
RaGe Posted January 22, 2008 Share Posted January 22, 2008 yeah i didnt wear my seat belt when i bedded mine it. i recieved a goose egg from em. love em. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
Richard B. Posted January 22, 2008 Author Share Posted January 22, 2008 yeah i didnt wear my seat belt when i bedded mine it. i recieved a goose egg from em. love em. what technique worked for you? i have never done it on any car. new or used, not even with a new brake job. Link to comment Share on other sites More sharing options...
RaGe Posted January 22, 2008 Share Posted January 22, 2008 when we did mine we got it up to 60 mph and slammed on the brakes. repeated this process about 4-5 times. then we let them cool down and did it again for 4-5 times. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
SLegacy99 Posted January 22, 2008 Share Posted January 22, 2008 Stock brakes not that good? Thats dissapointing. I am always impressed with the brakes I have on my '99. This car can stop and I have had a few close calls on a dangerous road near me with dogs running out and people trying to pass and causing accidents (which was an absolutely terrifying exprience). Couldn't ask for anything better, though if I had a turbo..... Link to comment Share on other sites More sharing options...
Scoobeedooby Posted January 22, 2008 Share Posted January 22, 2008 When you say slam on the brakes.. Like hard enough for the ABS to kick on? Link to comment Share on other sites More sharing options...
RaGe Posted January 22, 2008 Share Posted January 22, 2008 as hard as you can press that pedal. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
Scoobeedooby Posted January 22, 2008 Share Posted January 22, 2008 crap... Its prolly a little to late to do this with my car.. i have 3700 miles on it and the brakes are a little weak. Link to comment Share on other sites More sharing options...
slimjoe Posted January 22, 2008 Share Posted January 22, 2008 It shouldn't matter. You can redo the bed-in procedure whenever you want. It should remove any previous pad deposits that are on the rotors and all that good stuff. Link to comment Share on other sites More sharing options...
pillboy Posted January 22, 2008 Share Posted January 22, 2008 yeah i didnt wear my seat belt when i bedded mine it. i recieved a goose egg from em. love em. One goose egg or 4 to 5? It is still ugly. Link to comment Share on other sites More sharing options...
Richard B. Posted January 22, 2008 Author Share Posted January 22, 2008 Stock brakes not that good? Thats dissapointing. I am always impressed with the brakes I have on my '99. This car can stop and I have had a few close calls on a dangerous road near me with dogs running out and people trying to pass and causing accidents (which was an absolutely terrifying exprience). Couldn't ask for anything better, though if I had a turbo..... ahem...it was mostly "high speed" braking that he car is lacking in. below 60 is ok. after that i get the shakes. Link to comment Share on other sites More sharing options...
Richard B. Posted January 22, 2008 Author Share Posted January 22, 2008 question for those who did upgrade...did you do all 4 corners or just the front? me? i did all 4. Link to comment Share on other sites More sharing options...
STG Posted January 22, 2008 Share Posted January 22, 2008 Stock brakes not that good? Thats dissapointing. I am always impressed with the brakes I have on my '99. This car can stop and I have had a few close calls on a dangerous road near me with dogs running out and people trying to pass and causing accidents (which was an absolutely terrifying exprience). Couldn't ask for anything better, though if I had a turbo..... Here we go with another automotive myth. The stock Subaru Legacy GT brakes are fine for street use. The pads are fine as long as your not running on a track or driving real fast on mountain roads. As long as the braking system can lock up (or apply enough pressure to engage ABS), stopping prower will be determined by the coefficient of friction of the road and tires. Stopping distances will remain virtually unaffected. Higher performance brake pads will probably help decrease stopping distances after repeated brake applications as the brakes heat up. If your driving style really heats up the brakes, your primary concern should be the wet boiling point of that brake fluid you've never replaced. That sinking feeling you get when you ride your brakes all the way down a mountain and your pedal goes to the floor and you fly off a cliff is mostly due to your brake fluid boiling. If you ever go to Pikes Peak, you will notice a little checkpoint about 1/2 way up the mountain. Coming down you must stop as a ranger points a laser thermometer at your front brakes. If they're too hot, the rangers will make you. Their thermometers peg at 888 degrees F. and they see that often. That's a disk temp. of 888+ F. Old DOT 3 brake fluid may have a boiling point barely above 212F. Ask the rangers about the clown in the Subaru wagon. 888+ degrees at the checkpoint followed by 45 minutes of cooling off. He rode his brakes down the rest of the mountain (no check point at the bottom) and all four brakes caught on fire less than a mile from the parkj entrance. Link to comment Share on other sites More sharing options...
SLegacy99 Posted January 22, 2008 Share Posted January 22, 2008 If your driving style really heats up the brakes, your primary concern should be the wet boiling point of that brake fluid you've never replaced. I guess thats what I was wondering is if there is much fading. Ive driven quite a bit through the appalachians and not had a problem, but roomate's Legend's rear brakes heat up pretty quick and thus his rotors are warped. Link to comment Share on other sites More sharing options...
ehsnils Posted January 22, 2008 Share Posted January 22, 2008 ahem...it was mostly "high speed" braking that he car is lacking in. below 60 is ok. after that i get the shakes. It sounds to me that the rotors are uneven or warped and has to be replaced. Link to comment Share on other sites More sharing options...
Richard B. Posted January 24, 2008 Author Share Posted January 24, 2008 It sounds to me that the rotors are uneven or warped and has to be replaced. nope. got the pads done. zero shaking or anything. dead smooth. it's what should have come on the car. didn't get the rotors turned or anything. Link to comment Share on other sites More sharing options...
