Mr. CentralOhioSubarus Posted December 28, 2004 Share Posted December 28, 2004 It's nothing terrible, but being a developer, I found it interesting. If you are going down a hill and you hold the Coast, and your car speeds up because of the incline, and you release the Coast, then the cruise will be set at the higher MPH. It's just a flaw in the software IMHO. Neither my old 2000 2.5RS, nor my wife's 2004 Leggy act this way. Link to comment Share on other sites More sharing options...
agctr Posted December 29, 2004 Share Posted December 29, 2004 Do you honestly think its a flaw in the software, I would think that is the way it is to respond. If your pushing the CC up as yr going down the hill and then release, it will set it at that speed. Adam. Link to comment Share on other sites More sharing options...
Mr. CentralOhioSubarus Posted December 29, 2004 Author Share Posted December 29, 2004 It just seems illogical to me. If I push the "slow down" on the cruise control, and I set a higher speed, just because I'm going down hill, that seems wrong to me. They may have just changed to software to work that way, but it seems wrong. Link to comment Share on other sites More sharing options...
RoundBoy Posted December 29, 2004 Share Posted December 29, 2004 if you TAP the cruise control down... you will set the speed to 1 mph lower for every tap. if you HOLD the control down... all you are telling the computer to do is NOT accelerate. When you release... you are setting the new speed. Because you went downhill.. your speed is higher.. and you are setting the now higher speed. if you left it alone.. you would have the car not not accelerate at all, and return to the set speed. if you kept tapping the control down to the speed you wanted.. you would slow the car down. I ride the cruise control by tap... +1 - 1 all the time. If i need to slow down greatly to a new speed... i turn the system OFF... then turn it back on by tapping the control down. It seems to respond much more quickly in traffic that is going 70, then 55, then 65... Link to comment Share on other sites More sharing options...
KTM 525 Posted December 29, 2004 Share Posted December 29, 2004 Yeah even on my Hyundia if the CC is set and I push the coast button it will slowly drop speed until I release the coast button. At that point the new speed is set. So it would make sense if going down a hill the car will pick up speed due to gravity and all else will work the same. Dont see a flaw with that setup though. Link to comment Share on other sites More sharing options...
SBT Posted December 29, 2004 Share Posted December 29, 2004 Better just to set it to "coast" then "set" when you re-reach the speed you want. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
S4 Posted December 29, 2004 Share Posted December 29, 2004 I found another bug in the cruise software. I can't get it to set over 89.... Link to comment Share on other sites More sharing options...
sde Posted December 29, 2004 Share Posted December 29, 2004 I found another bug in the cruise software. I can't get it to set over 89.... Link to comment Share on other sites More sharing options...
Hatt Marrington Posted December 29, 2004 Share Posted December 29, 2004 you can in 4th gear not that you would want to I was having a fun time making the car take off using the CC paddle, and noticed i was going 100 mph the other night -Hatt 2005 Obsidian Black Legacy GT 5MT Un-Limited Sedan Link to comment Share on other sites More sharing options...
Bruno1453 Posted December 29, 2004 Share Posted December 29, 2004 With an automatic I could see the car downshifting to attain a lower speed. But for a manual, you would have to tap into the ABS somehow and have the brakes slow down the car. Then you would have to worry about someone holding down the coast for too long and loosing the brakes. Much too much effort, and dictates two different systems altogether. Hit your brake, slow down to where you want to be, reset cruise, and be happy you own a GT instead of us whom are still dreaming. Link to comment Share on other sites More sharing options...
S4 Posted December 29, 2004 Share Posted December 29, 2004 you can in 4th gear not that you would want to I was having a fun time making the car take off using the CC paddle, and noticed i was going 100 mph the other night Well, I can go as fast as I want with the paddle. Say you don't have cruise set at all. Go 90 or faster and press set and it won't do anything. Set it at 89 or below and press accel and it'll go till you let it go. It'll just go back down to the last speed it was set at (or maybe 89?). Link to comment Share on other sites More sharing options...
frankjdattco.com Posted December 29, 2004 Share Posted December 29, 2004 I've gotten my 05 Legacy past 89 with cruise. Mine kinda feels like its Breaking when i go down hill in Cruise. Is that normal? Link to comment Share on other sites More sharing options...
Xaqtly Posted December 29, 2004 Share Posted December 29, 2004 Mine stops at 90 also. Believe me, I tried to get it to go higher. Link to comment Share on other sites More sharing options...
frankjdattco.com Posted December 29, 2004 Share Posted December 29, 2004 I put quite a bit into my car since i bought it so maybe thats why mine goes higher. Link to comment Share on other sites More sharing options...
fan42025 Posted December 29, 2004 Share Posted December 29, 2004 Coast by definition means cruise, drift, float, freewheel. So, if you are going down hill and you are speeding up (normal), then using coast will comply. Releasing the coast control sets the cruise to the new speed, as expected. What would be neat is instead of coast, it was decrease, using breaks automatically where necessary to slow the car down. I just do what others have already said - I turn off the cruise and/or apply breaks and/or change to a lower gear to slow down on a decline. Can't have the car do everything for us, yet. I suppose once we all have cars like the prototype Audi in I-robot, we'll have less to complain about. Link to comment Share on other sites More sharing options...
Deer Killer Posted December 29, 2004 Share Posted December 29, 2004 It does decelerate, through engine braking. I've had no speed changes going through the hills in western mass on I-90, and it gets steep there. Link to comment Share on other sites More sharing options...
agctr Posted December 29, 2004 Share Posted December 29, 2004 Yes even in Ferrari and Porsche, they do have upper limits in their ability to set crusie over a certain speed. Adam. Link to comment Share on other sites More sharing options...
