unlimited6986 Posted January 20, 2008 Share Posted January 20, 2008 This is the 2nd time ive got this. They both happened when i took like a hour trip. The check engine light pops up and the cruise control blinks. So i took out the access port to check it and it says no codes. So i tried it w/ the green plugged in and w/out and still says nothing. So i loaded the stage 2 map again and it goes away. This ever happen to anyone here? Link to comment Share on other sites More sharing options...
ABPillinois Posted January 20, 2008 Share Posted January 20, 2008 I had one the otherday after I started the car it had a check engine light w/ cruise control blinking. AP says no cel codes reset ecu and hasn't come back since. :rolleyes:"All right, brain, I don't like you and you don't like me - so let's just do this and I'll get back to killing you with beer." Link to comment Share on other sites More sharing options...
BoOCh_00_GT_Ltd Posted January 20, 2008 Share Posted January 20, 2008 no history codes even? Link to comment Share on other sites More sharing options...
qikslvr Posted January 20, 2008 Share Posted January 20, 2008 The AP isn't the best at pulling codes. You may want to go to a parts store and use their code reader to pull the code if it happens again. Let's kick this pig! Link to comment Share on other sites More sharing options...
unlimited6986 Posted January 20, 2008 Author Share Posted January 20, 2008 Nothing at all just says no cel found. Nothing will come up now if i go to subby to find it will it? I just gotta wait till it pops up? My friend is the master tech there. Link to comment Share on other sites More sharing options...
ejoy1220 Posted January 20, 2008 Share Posted January 20, 2008 The AP isn't the best at pulling codes. You may want to go to a parts store and use their code reader to pull the code if it happens again. Or use the car's built-in code reader. Link to comment Share on other sites More sharing options...
qikslvr Posted January 20, 2008 Share Posted January 20, 2008 Next time the CEL comes on take it to a shop or parts store and pull the code. When you reloaded the map; it reset the ECU and deleted all stored codes. I've tried to pull codes with the AP before and it came up with nothing, but when I went to the parts store and used their reader it came up with several stored codes. For whatever reason; the AP just doesn't perform real well as a code reader. Works great to reset the ECU and erase the code, but it just doesn't read them very well. Let's kick this pig! Link to comment Share on other sites More sharing options...
Carter Posted January 20, 2008 Share Posted January 20, 2008 Or use the car's built-in code reader. explain, I havent heard of this... Link to comment Share on other sites More sharing options...
ejoy1220 Posted January 21, 2008 Share Posted January 21, 2008 explain, I havent heard of this... Works pretty good http://legacygt.com/forums/showthread.php?t=60436&highlight=built+code+reader Fish out the connectors, plug them in, and hold the reset/select stalk on the instrument cluster etc etc Link to comment Share on other sites More sharing options...
qikslvr Posted January 21, 2008 Share Posted January 21, 2008 Check the first post in this thread for the built in code reader for 2006+ models: http://legacygt.com/forums/showthread.php?t=57243&highlight=code+reader Check the first post in the this thread for 2005 I believe: http://legacygt.com/forums/showthread.php?t=23292&highlight=code Let's kick this pig! Link to comment Share on other sites More sharing options...
CodyItaliano Posted January 21, 2008 Share Posted January 21, 2008 hey mine does this same thing. i have cobb stage 2 tuning, so i dunno if i can do much. i havent had a chance to put a scanner on it, havent had any problems at all though as far as driveability. Link to comment Share on other sites More sharing options...
unlimited6986 Posted January 21, 2008 Author Share Posted January 21, 2008 i got the cobb stage 2 too. Ill just go to subaru when it comes back on. Thx for the help guys. Link to comment Share on other sites More sharing options...
