Andreu Posted January 8, 2008 Share Posted January 8, 2008 well in the of process of finishing my audio upgrade, and i have run into a problem. i dont know how im going to run my power cable. if you guys could give me some instructions id appreciate it and follow up with some pictures. Thanks Link to comment Share on other sites More sharing options...
str8dwn Posted January 8, 2008 Share Posted January 8, 2008 From battery to inside firewall: http://www.legacygt.com/forums/showpost.php?p=1312191&postcount=15 After that, you can either run it down the trans tunnel under the console like I did or choose a side opposite any RCAs or signal wiring. Link to comment Share on other sites More sharing options...
Andreu Posted January 8, 2008 Author Share Posted January 8, 2008 For some reason my break fluid resivour is in that spot. That must be the diffrence from the wagons. I did find a spot on the other side by the down pipe. Link to comment Share on other sites More sharing options...
whobaru Posted January 8, 2008 Share Posted January 8, 2008 My car didn't have that grommet, so if you don't, then if you make your hole precisely in this spot, you can run a wire fish through and see where it comes out in the engine bay. Cut the rubber/foam insulator with a razor knife, then use a unibit/step-bit to make your hole. I used a plastic grommet to finish off the hole. http://i180.photobucket.com/albums/x312/kagenmateer/IMG_2929.jpg Link to comment Share on other sites More sharing options...
Andreu Posted January 8, 2008 Author Share Posted January 8, 2008 My car didn't have that grommet, so if you don't, then if you make your hole precisely in this spot, you can run a wire fish through and see where it comes out in the engine bay. Cut the rubber/foam insulator with a razor knife, then use a unibit/step-bit to make your hole. I used a plastic grommet to finish off the hole. http://i180.photobucket.com/albums/x312/kagenmateer/IMG_2929.jpg Do you have a sedan? How hard was it for you to drill out that spot? Link to comment Share on other sites More sharing options...
FJuan Posted January 8, 2008 Share Posted January 8, 2008 ^^There's a plug there that you can use next to the brakes. Here's a few pics from my install. My amp is under the drivers seat http://im1.shutterfly.com/procserv/47b7d731b3127ccebba81bde290000000036100AZtHDZo1bt2KA http://im1.shutterfly.com/procserv/47b7d731b3127ccebba8e5fea86f00000036100AZtHDZo1bt2KA Inside the quarter panel going into the cabin. (red wire) http://im1.shutterfly.com/procserv/47b7d731b3127ccebba81bae297000000036100AZtHDZo1bt2KA http://im1.shutterfly.com/procserv/47b7d731b3127ccebba8fa25e82300000036100AZtHDZo1bt2KA My wife's balls are delicious. Link to comment Share on other sites More sharing options...
whobaru Posted January 8, 2008 Share Posted January 8, 2008 ^^There's a plug there that you can use next to the brakes. Wasn't big enough for my 4 gauge. I had a few options for 8 gauge, but not 4. Link to comment Share on other sites More sharing options...
Andreu Posted January 8, 2008 Author Share Posted January 8, 2008 I found an opening by the glove box in the engine bay. anyone try this spot before? Link to comment Share on other sites More sharing options...
whobaru Posted January 8, 2008 Share Posted January 8, 2008 I don't think anyone has. I looked over there, but didn't see anything worth the effort. Seriously though, if you pop a hole exactly where I did, you're money. Link to comment Share on other sites More sharing options...
Andreu Posted January 8, 2008 Author Share Posted January 8, 2008 alright well i will have to give it a shot. ill let you guys know how i fair out. Link to comment Share on other sites More sharing options...
whobaru Posted January 8, 2008 Share Posted January 8, 2008 If you make your own hole, just make sure you use a grommet. Over time, the sharp metal can wear through the jacket on your power wire and cause it to short and blow your fuse, or possibly cause a fire. Link to comment Share on other sites More sharing options...
Andreu Posted January 8, 2008 Author Share Posted January 8, 2008 where can i purchase grommets? Link to comment Share on other sites More sharing options...
