Andreu Posted January 6, 2008 Share Posted January 6, 2008 Does anyone know how i could plug in the ign wire 12= wire and swithch wire the best way? Link to comment Share on other sites More sharing options...
str8dwn Posted January 6, 2008 Share Posted January 6, 2008 By getting a female and male Subaru WRX/Legacy radio harness from SVXDC (http://www.geocities.com/svxdc/Ordering.htm), you can tap into the radio's 8 speaker wires, constant +, switched + and ground. All without cutting the original factory plug. HIGHLY recommend this approach. Also, the JL XB-BLU9CON-20 9 wire OEM speaker cable is perfect for this. It runs all 8 speaker wires in a tight bundle to the CS for you. Hi Fi Buys or your JL dealer should have it. (http://mobile.jlaudio.com/products_connections_detail.php?cat_id=19) Link to comment Share on other sites More sharing options...
