NSFW Posted December 26, 2007 Share Posted December 26, 2007 My conscience will allow me to ditch the UP cat, and one of the DP cats, but won't allow me to run fully catless. Looking at dyno sheets I get the impression that cats actually do cost a fair amount of horsepower (like 10hp or more). So I'm wondering if it would be feasible to get a catless DP and weld in an oversized cat, such as one intended for larger-diameter exhaust pipes, or maybe something with an oval-shaped cross-section. Is there enough room under the car, near the end of the DP, to weld in a bigger-than normal cat? Stuff like... http://www.car-sound.com/02product/universal/942.asp http://www.car-sound.com/02product/universal/mirror.asp http://www.car-sound.com/02product/universal/430.asp Or is it just too tight in there? Link to comment Share on other sites More sharing options...
lucas569 Posted December 26, 2007 Share Posted December 26, 2007 why spend so much $$$, time AND labor when you can get one of the many high flow catted dp 's??? Link to comment Share on other sites More sharing options...
NSFW Posted December 27, 2007 Author Share Posted December 27, 2007 By "bigger than normal" I mean "bigger than what Cobb, Perrin, etc, are using." Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 27, 2007 Share Posted December 27, 2007 I believe these are ceramic cats and don't flow as well as the metallic substrate cats that Cobb and others are using. However, I believe these are more efficient in eliminating emissions and are actually legal for stock replacement after your car has exceeded the 5 year stock emissions period. Link to comment Share on other sites More sharing options...
hogmeat Posted December 27, 2007 Share Posted December 27, 2007 you'll pass any sniff test with a metallic cat - they are "small" but they clean it up enough. If it eases your conscience - I'm pumping the atmosphere full of hydrocarbons. Although, it's only at a rate of 3,000 miles a year I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
